I’m unclear as to what mechanism will make sure that my external URL the HA webserver is advertising will still be the same as what’s on the letsencrypt certificate. Does anyone know how to migrate that information?
Hello
I made these changes and it worked, I use Duckdns, but soon after I realized that the voice commands through Google Assistant did not work anymore. Is there anything else to change?
I added the urls as per the instructions above in those fields. However I am unable to access my duckdns url anymore. If I removed the base_url component from configuration.Yaml.
I removed base_url: https://???.duckdns.org:8123 from http: base_url: https://?????.duckdns.org:8123
from http: in configuration.yaml.
When I go to setup in General Configuration the External URL/Internal URL it is not accessible - “Editor disabled because config stored in configuration.yaml”
I am running Home Assistant 0.112.2/HassOS 4.11 on a NUC. I have restarted server & host but I am now unable to reach Home Assistant via DuckDNS
What am I doing wrong?
Just noticed I posted my own similar thread about this and failed to search so bad on me. I see the message in the logs to remove the base_url, what specifically am I removing? So in my configuration.yaml I have:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: https://<URL>
server_port: 8123
ssl_certificate: /ssl/<URL>-chain.pem
ssl_key: /ssl/<URL>-key.pem
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
- 192.168.0.14
Do I just remove the base_url: https://<URL> piece and place it in the Configuration > General area or do I need to do something with the port or all the entries?
I deleted the base_url: & server_port: lines and now its working again.
However the Settings for External URL: & Internal URL: in Configuration - General is still greyed out & showing “Editor disabled because config stored in configuration.yaml”
homeassistant:
# some basic information on where we are ...
#name: Home
#latitude: !secret HOME_LATITUDE
#longitude: !secret HOME_LONGITUDE
#unit_system: metric
#time_zone: Australia/Sydney
#elevation: 178
I can give it a try but not a duckdns user. I have my own GoDaddy certs and DNS. From what I see above sounds like with the rest of my settings for ssl certs and the like still in there the options in General will still stay grayed out which wouldn’t work.
I removed the latitude, lingitude, elevation, unit_system, time_zone and name from the homeassistant: block and everything became editable which was interesting since the base_url was still in the configuration.yaml. That said, I removed the base_url value now from configuration.yaml and appended :8123 on my external URL that was guessed in the field and seems like it’s working.
Instead of removing all of those items from configuration.yaml, you could have replaced base_url: with external_url:. Nothing wrong with using the UI for configurating that information though–just wanted to explain why the editor was disabled.
Question on this. When you do it thru the GUI and using mariadb/mysql does that data get kept in the DB or elsewhere? I know in the past like past as in going to version 0.112 the migration script didn’t work and had to wipe out the DB but wasn’t sure if that was just the logbook data or what.
