But that still doesn’t matter
Thats only a concern for everything outside of hassio.
I just nuked my system the other day, new 19.0 Ubuntu and hassio in docker.
I have no python on the host just In the hassio docker venv
No he did, even listed it.
Raspberry Pi 4
But either way his original concern was enabling the HA Bluetooth integration which we both agree doesn’t require him to install or update anything for it to work as everything is already there.
Hi John,
because hassio is built in a special environment (docker container within a reduced non standard operation system - hassOS: https://www.home-assistant.io/blog/2018/07/11/hassio-images/) you have only a reduced set of commands.
Try: core-ssh:~# hassio help (in CLI).
So your problem could result due to lack of an appropriate power supply?
Hi guys, thanks for the support on this. I did my best to describe the environment but clearly missed something.
The Raspberry Pi 4 was brand new and I have simply downloaded
hassos_rpi4-3.7.img.gz
from https://www.home-assistant.io/hassio/installation/
and setup Home Assistant. So I do not have a standard linux env. Should I have started with installing Linux and then Home Assistant?
What I really want to do is capture the Bluetooth commands sent by the remote control (or phone app) to my Huna blinds. Then I can automate them to open/close. No other integration is available as they outline on their FAQ
I thought I would start by discovering the MAC address using Bluetooth tracker, but came across the issue I posted above.
