I realize this is a very basic question, but I seem to missing how to start. I installed the pi-hole add-on (hass.io inside a docker container) and when I open the webui I get a message that says “Failed host check” for my FQDN. I can access it via the internal IP, but I always use my FQDN instead. A quick search tells me I need to “edit my configuration file and add the virtual host.” Here comes the dumb question… what is the configuration file?
I found a few files that look like what I’ve seen people paste configuration from, and I edited those, but when I then restart the add-on, the file reverts itself and removes my virtual host entry.
What’s the proper path to use to find the configuration file for an add-on? Thanks!
