I am soooooooo new to all of this so I will say that up front. That said I am trying to play around and I figured out how to get my doorbell to stream video so that is cool, go me.
Now I am tring to make my own dashboard to play around (Eventually i’ll do that tablet thingy) and having a tough time.
If I go to the “home” tab I created I can click onthe 3 dots>edit dashboard>"+ add card" and somehow cobbled together a camera card. The problem is there is no save button and when I click done it does not save to the “home” dashboard. If I click Edit Dashboard again it does show there.
Am I not understanding things here? Pic for reference. I just want the lovelace (Is that what its called?) card to be on the home dashboard I am messing with. I am just trying to learn the system here.
If it matters its a linux VM on an unraid server (first one of those too, lol).
Could you send us the yaml code for the stack containing the two camera cards?
Click the Edit button below the bottom image, then click SHOW CODE EDITOR in the bottom left corner. Then copy the yaml code. Please use the code formatting tool when adding your code to your reply.
I’m not sure what affects the state of the entity binary_sensor.doorbell_streaming_sensor_streaming_sensor but, only when it is true will the image appear.
It’s not quite right to say it only shows when there is a trigger - this would be more to do with an automation. In this case the dashboard card changes depending on the condition set.
