Bought a few ESP32-C6-EVB boards on Tindie for $15 each. Here is an ESP Home config that enables all four relays, four opto-coupler inputs, status LED and BOOT button. I got the BLE working too with a specific ESP-IDF setup.
Tindie: https://www.tindie.com/products/adz1122/esp32-c6-evb-wifi6-support-tasmota-4-relay-4input/
Company product page: developmentboard:esp32-c6-evb [ICBbuy]
esp32-c6-evl.yaml
esphome:
min_version: "2025.4"
friendly_name: ESP32 C6 EVB
project:
version: "1.0"
esp32:
board: esp32-c6-devkitc-1
variant: esp32c6
flash_size: 4MB
framework:
type: esp-idf
version: 5.3.1
platform_version: 6.9.0
sdkconfig_options:
CONFIG_ESPTOOLPY_FLASHSIZE_4MB: y
CONFIG_BT_BLE_50_FEATURES_SUPPORTED: y
CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
CONFIG_OPENTHREAD_ENABLED: n
CONFIG_ENABLE_WIFI_STATION: y
CONFIG_USE_MINIMAL_MDNS: y
# Enable logging
logger:
# Enable Home Assistant API
api:
password: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "ESP32-C6-EVB Fallback Hotspot"
password: "12345678"
captive_portal:
# https://wiki.icbbuy.com/doku.php?id=developmentboard:esp32-c6-evb
esp32_ble_tracker:
max_connections: 5
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
continuous: false
bluetooth_proxy:
active: true
connection_slots: 5
- platform: wifi_signal
update_interval: 60s
# I2C crashes with the esp-idf version needed for BT but only exposed on the UEXT pins anyway
# i2c:
# sda: 6
# scl: 7
# frequency: 15kHz
light:
- platform: status_led
pin:
number: 8
inverted: true
ignore_strapping_warning: true
mode: output
binary_sensor:
- platform: gpio
pin:
number: 9
inverted: true
mode:
input: true
pullup: true
- platform: gpio
pin:
number: 1
inverted: true
mode:
input: true
pullup: true
- platform: gpio
pin:
number: 2
inverted: true
mode:
input: true
pullup: true
- platform: gpio
pin:
number: 3
inverted: true
mode:
input: true
pullup: true
- platform: gpio
pin:
number: 4
inverted: true
mode:
input: true
pullup: true
switch:
- platform: restart
- platform: gpio
pin: 10
- platform: gpio
pin: 11
- platform: gpio
pin: 22
- platform: gpio
pin: 23
