Basic help with a basic alarm panel
[SOLVED] I want to create an alarm panel in HA.
I read this
https://scotthelme.co.uk/creating-a-house-alarm-system-with-home-assistant/
Scott said it is “really simple”…that’s my kind of language…
I have also read the documentation here
My configuration.yaml file looks like this
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Example configuration.yaml entry
alarm_control_panel:
  - platform: manual
I then created a new dashboard called ‘Alarm’ and clicked the button to add a card
but then I got this:
I’ve tried copying other examples from here but I am obviously missing something.
What’s not obvious (to me) is what I am missing…?
Try to install the Alarmo integration.
It’s simple to configure.
Thanks for your prompt response.
Alarmo looks very interesting although the process to get there (eg. install HACS, use SSH) looks challenging (for me).
I’ll give it a go, though.
Thanks again.
@barroco69 Thank you so much for that.
The process wasn’t as bad as I feared.
During the installation of the Alarmo integration I got “Configuration Invalid!” and I found that I had left the old ‘alarm_control_panel’ in configuration.yaml.
Once I had deleted that the integration installed as required and I now have a functioning alarm panel.
Thanks again!
