Hi
Is it possible to use basic led with nodemcu and esphome? if yes, how should i connect/wire it?
Hi
use this code example:
wire from a 3.3v pin via a resistor, to the LED, to the GPIO pin that you program as per above
worked perfectly, thanks!
