While addressing an issue of zigbee2MQTT failing, suspected over load/hue bulb issues, I am moving 80 odd hue lights back to 2 Hue hubs to stabilise things and also get some stability back and stop annoying my wife when zigbee2MQTT crashes leaving her walking into a dark room.
So moved (about half) the lights and now updating existing Home Assistant automations.
I am trying to work out how set a Hue Bloom light in the Hue integration to Red 20% brightness, or Green 20% brightness.
I can see a way to turn on or off the light.
I can see by using scene I can set the brightness.
Each time I saved the changes it lost the changes.
Tried three times each after saving it lost the changes.
So copied it all to Studio code Server, edit it there then copied it back after deleting the existing YAML, one char at a time as there does not appear a way to select all and then delete
Ok getting there - those pesky invisible spaces !!!
I think I have the Yaml fixed
I found the Then do Lights/Turn on option, I had been thrown by the choose area/devices/entity/label options
Once I had that just need to work out how to set the colour - had expected a colour wheel but figured it out.
I have moved 40 odd Hue Lights and ~10 motion sensors and hopefully that reduces the zigbee2MQTT workload enough for it to stabilise and not just loose every devices every 5-7 days
