I’m splitting up my configuration for better overview and struggle a bit on the way how I had to add packages as in the doc (link):
homeassistant:
packages: !include_dir_named packages
Especially the “home assistant:” “thing”. Why I had to do this? (indent package under homeassistant and not put it in a single line like other includes)
I thought "basic things like homeassistant:
are in default_config:
Does it matter where I put this homeassistant:
? In the “Splitting up the configuration”-Doc its typically show on the topmost line ?
(I’ll attach my configuration.yaml at the end of this post)
Also: To me the packages look very elegant to split up. Can I use this also for automations that are not done by the UI?
(or should I better use a “automation block as explained here in the doc”?)
And finały (in addition to “check configuration”) is there a possibility to look at the assembled config after all includes (and with secrets) ?
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
### mhoff below
# Load config files https://www.home-assistant.io/docs/configuration/splitting_configuration/
recorder:
purge_keep_days: 32
notify: !include notify.yaml
panel_custom: !include panel_custom.yaml # https://smarterkram.de/1862/
# custom packages - https://www.home-assistant.io/docs/configuration/packages/
homeassistant:
zha:
custom_quirks_path: /config/custom_zha_quirks/
zha_toolkit:
wake_on_lan:
