Basic shell Command not working on call
Hi im on Ha 0.97.2 on Raspberry with hassio
I tried to make a simple script that calls a shell command service to restart the Raspberry
I write in path \home assistant\shell_command\shell_command.yaml the:
rebootpi:‘ssh pi@xxxxx sudo reboot’
i make a script \home assistant\scripts\reboot pi.yaml to call the service:
reboot_pi:
alias: Reboot the Pi
sequence:
- data: {}
service: shell_command.rebootpi
also i included on confiquratior file without errors on check file :
shell_command: !include_dir_merge_named shell_command
but when i run from scripts that already shows i get this error:
Failed to call service script/reboot_pi. Unable to find service shell_command/rebootpi
How bizarre. Why are you using ssh to log into the host that is already running home assistant. How about
shell_command:
    reboot_pi: sudo reboot
I changed but still get the same error
Have you fixed the problem?
I have the same problem.
My installation is Raspbian GNU / Linux 10 (buster)
configuration.yalm
shell_command:
restart: ./media/jbreboot
Script: jbreboot
pi@raspberrypi:/media $ ls -l jbreboot
-rwxrwxrwx 1 pi pi 111 de febr. 7 21:15 jbreboot
#!/bin/bash
LOGFILE="/media/LogReboot.txt""
echo Init > $LOGFILE
sudo reboot >> $LOGFILE
echo end >> $LOGFILE
Execute script from Home Assistant. this execution create a log file /media/LogReboot.txt
but not reboot the system.
pi@raspberrypi:/media $ ls -l LogReboot.txt
-rw-r–r-- 1 homeassistant homeassistant 9 de febr. 7 21:19 LogReboot.txt
and the content of file log are:
pi@raspberrypi:/media $ cat LogReboot.txt
Init
end
i think it ignores the reboot statement
can anyone help me?
