Having trouble with a basic temperature trigger. Have a fan that I want to turn on when the temperature gets above a certain point in my office and have the following automation yaml (I used the visual tool and this is the output):
alias: Office Fan
description: Activates fan in office when temperature gets too high.
- platform: numeric_state
entity_id: sensor.office_temperature
above: '70'
condition:
- condition: device
type: is_off
device_id: 06815a34d2ce252a289bbbab50080b0b
entity_id: switch.office_fan_on_off
domain: switch
for:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
- type: turn_on
domain: switch
mode: single
If I just run the action the fan turns on just fine. Then if I go into the developer tools and set the state of sensor.office_temperature to something ridiculous like 90, I get the following in my debug-level-logs:
2021-03-27 03:07:17 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.office_temperature, old_state=<state sensor.office_temperature=78.4; unit_of_measurement=Ā°F, friendly_name=Office Temperature, device_class=temperature @ 2021-03-27T03:00:15.287506-04:00>, new_state=<state sensor.office_temperature=90; unit_of_measurement=Ā°F, friendly_name=Office Temperature, device_class=temperature @ 2021-03-27T03:07:17.193697-04:00>>
2021-03-27 03:07:17 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [2861361880] Sending {"id": 90, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "sensor.office_temperature", "old_state": {"entity_id": "sensor.office_temperature", "state": "78.4", "attributes": {"unit_of_measurement": "\u00b0F", "friendly_name": "Office Temperature", "device_class": "temperature"}, "last_changed": "2021-03-27T07:00:15.287506+00:00", "last_updated": "2021-03-27T07:00:15.287506+00:00", "context": {"id": "52a408ea23e32df30760df8f8d4369f0", "parent_id": null, "user_id": null}}, "new_state": {"entity_id": "sensor.office_temperature", "state": "90", "attributes": {"unit_of_measurement": "\u00b0F", "friendly_name": "Office Temperature", "device_class": "temperature"}, "last_changed": "2021-03-27T07:07:17.193697+00:00", "last_updated": "2021-03-27T07:07:17.193697+00:00", "context": {"id": "8882b5e041a8143186d38e9a3d553b5a", "parent_id": null, "user_id": "8a32d8373d2e4546b3897391b84226b0"}}}, "origin": "LOCAL", "time_fired": "2021-03-27T07:07:17.193697+00:00", "context": {"id": "8882b5e041a8143186d38e9a3d553b5a", "parent_id": null, "user_id": "8a32d8373d2e4546b3897391b84226b0"}}}
2021-03-27 03:07:17 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [2922715792] Sending {"id": 30, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "sensor.office_temperature", "old_state": {"entity_id": "sensor.office_temperature", "state": "78.4", "attributes": {"unit_of_measurement": "\u00b0F", "friendly_name": "Office Temperature", "device_class": "temperature"}, "last_changed": "2021-03-27T07:00:15.287506+00:00", "last_updated": "2021-03-27T07:00:15.287506+00:00", "context": {"id": "52a408ea23e32df30760df8f8d4369f0", "parent_id": null, "user_id": null}}, "new_state": {"entity_id": "sensor.office_temperature", "state": "90", "attributes": {"unit_of_measurement": "\u00b0F", "friendly_name": "Office Temperature", "device_class": "temperature"}, "last_changed": "2021-03-27T07:07:17.193697+00:00", "last_updated": "2021-03-27T07:07:17.193697+00:00", "context": {"id": "8882b5e041a8143186d38e9a3d553b5a", "parent_id": null, "user_id": "8a32d8373d2e4546b3897391b84226b0"}}}, "origin": "LOCAL", "time_fired": "2021-03-27T07:07:17.193697+00:00", "context": {"id": "8882b5e041a8143186d38e9a3d553b5a", "parent_id": null, "user_id": "8a32d8373d2e4546b3897391b84226b0"}}}
But no errors and no mention of the automation, switch, anything.
Iām at a loss. I tried messing around with using a template trigger along the lines of:
{{ (states("sensor.office_temperature") | float) < 70 }}
and still no-go. Any insight is appreciated; I have no clue what Iām doing wrong. I even had this setup before just fine but I upgraded from a Pi 3 to a Pi 4 and did a reinstall of HA. Current version info:
core-2021.3.4
supervisor-2021.03.6
Thanks in advance for anyhelp!
