I suspect this is more of a basic “I do not understand z-wave” question than home assistant but any guidance would be appreciated.
For years I had a dozen or so z-wave devices working fine, mostly Zooz 4-in-one sensors, with three Aeon range extender 6’s. I use a separate rPi with zwavejs running (since HA is in a HyperV container with no usb access). All working perfectly.
Then I moved. To move I just took down all the devices, shut down the rPi and HyperV server, and moved. At the new house I used the same subnet and everything came up and was running except the zwaves.
The zwavejs UI works, and I can ping the range extenders, but none of the battery powered devices are responding. To be sure it’s not a distance thing, I brought them all into a spot about 20’ from the controller, and quite literally surrounded by the range extenders, and left them sitting over night. Nothing. Can’t ping the zooz devices, I CAN ping the range extenders. The zooz devices all show last activity date before the move.
All the batteries were fresh (mostly, showing 100%) before the move, but I swapped one’s battery just in case, and on several I power cycled them. Still nothing after a few hours (total time testing is now about 16 hours).
I feel like I’m just missing some basic step. In the past changes (e.g. replacing a battery) may take a few hours to show up, this is much longer.
The software is a tad out of date, I stopped updating when I started packing for the move. zwave-js is 12.3.0 and HA is 2024.2.1 (which I suspect is not really involved as I am troubleshooting on the zwave-js UI).
If I view statistics (in the zwave-js UI) from these devices there is no data shown. The log doesn’t show anything that is helpful, at least to me. Here’s a snippet that shows me trying to ping node 3. Note that the neighbor lists are showing from non-responding notes, but I think that just comes from the controller, they still show no activity.
The only thing that may have changed is I do not recall which USB port had the controller before, but since it can ping the mains powered devices I assume it is working. The rest is all the same hardware just picked up and moved.
Any thoughts or advice?
Am I just impatient? Does it really take more than 16 hours?
Linwood
