Real noob here and am trying to install a custom component. I am literally asking how to copy/paste Directions say “copy lutron_caseta_pro into directory.” So far I created a directory. Do i click on the top with the green button thingy - Do i Clone/Download? Git? I have FIleEditor and VSCode, and the GitDesktop. Its from here btw https://github.com/upsert/lutron-caseta-pro
Yes use the green button. Definitely download it as a zip file. If you don’t the format of the files will be corrupted.
You may only need part of what is downloaded inside the zip file but it’s the safest way.
Hey thanks!
So it’s just the files in the folders that I upload, right? the instructions say " Copy lutron_caseta_pro
from this project including all sub-directories into the directory custom_components
" but it clearly wont let me do folders. Also, does it have to be 1 file at a time only?
Try going up one level and downloading the whole repository.
Not sure I see that option, at least not in the file editor. Should I be trying this in VScode instead?
Use your web browser to go to: https://github.com/upsert/lutron-caseta-pro
