A lot that has been added to this new release. Hope you like it.
New Features
- Added a selection option to use the “Fan Speed - Switch Off Option”. Note: If you are using “Fan Speed - Off Switch Option” then you must now select to enable this option for it to work. It is the same function as before just the description has change and you must now enable it.
- Added a maximum humidity option to turn the fan ON. When using this option make sure you input your humidity sensor.
- Added winter mode settings.
- Added options for lights. If you have selected to use lights before in “Fan Switch” and they are a light entity then you will have more options for lights. It is recommended to remove them from “Fan Switch” input and add them now to the light options. If you have lights that are a “switch” entity then just add/keep your switch entities for your lights in “Fan Switch”.
Enjoy
Blacky
