🚿 Bathroom Humidity Exhaust Fan
Try using two blueprints “Timer Relay - Run ON Timer and Bathroom Humidity Exhaust Fan” and select the same fan. Putting it all into one blueprint can be tricky. Both of the blueprints are mine and its why I have a few.
Us this blueprint Timer Relay - Run ON Timer
Use this blueprint Bathroom Humidity Exhaust Fan
Hope this helps you
Blacky :grinning:
