I created this from an automation I have been using for awhile. Its not made in the traditional way most lighting automations are done. I prefer to use timers as they seem to be much more reliable especially if you are tinkering with automations alot. This method has proven to be pretty reliable in turning off the lights and fan.
This blueprint requires 2 sensors. A motion and a door/contact sensor.
It also requires 2 timers. One for the light and one for the fan.
It operates under the assumption that if the door is closed, the room is occupied. If it is occupied, we are assuming that you are doing something that may require the fan to be turned on. The light and fan will stay on as long as the door is closed.
You can set the time to turn on the fan after the door is closed. The fan timer will not activate until the door is closed.
The other timer selection is to choose the delay after last motion to when the lights turn off.
2 triggers can start the countdown trigger. Last motion, and opening the door. I did that for redundancy in case one trigger fails. Most of the time last motion wins out.
This is my first blueprint…
See the Gist
blueprint:
name: Bathroom Light and Fan Controller
description: Automate your bathroom light and fan
domain: automation
input:
motion_sensor:
description: The motion sensor used to trigger the lights
selector:
entity:
domain: binary_sensor
device_class: motion
door_sensor:
description: The door sensor used on the bathroom door
selector:
entity:
target_light:
description: The light you want to control
selector:
entity:
domain: light
target_fan:
description: The fan you want to control
selector:
entity:
light_timer:
description: This timer will control the light
selector:
entity:
domain: timer
fan_timer:
description: This timer will control the fan
selector:
entity:
domain: timer
light_off_time:
name: Lights out Time
description: Time it takes for the light and fan to turn off after last motion
default: 90
selector:
number:
min: 0
max: 3600
unit_of_measurement: seconds
fan_on_time:
name: Fan on Delay
description: Time it takes for the fan to turn on after closing the door.
default: 90
selector:
number:
min: 1
max: 3600
- platform: event
event_type: timer.finished
event_data:
entity_id: !input fan_timer
- platform: event
event_data:
entity_id: !input light_timer
- platform: state
entity_id:
- !input motion_sensor
to: "off"
- platform: state
entity_id:
to: "on"
- platform: state
entity_id:
- !input door_sensor
to: "off"
- platform: state
entity_id:
to: "on"
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: timer.start
duration: !input light_off_time
- service: light.turn_on
data: {}
entity_id: !input target_light
- conditions:
- condition: state
entity_id: !input motion_sensor
state: "off"
- condition: state
entity_id: !input door_sensor
state: "on"
sequence:
- service: light.turn_off
data: {}
- service: fan.turn_off
data: {}
entity_id: !input target_fan
- conditions:
- condition: state
state: "off"
sequence:
- service: fan.turn_on
data: {}
- conditions:
sequence:
duration: !input fan_on_time
- conditions:
sequence:
entity_id:
- !input light_timer
default: []
mode: restart
max_exceeded: silent
