All of my doors and windows are in my system via Konnected. They all report as Open/Closed which is correct. I have a single battery operated door/window sensor on my garage door that I’ve added but for some reason it reports as On/Off. Is there any way to change this to Open/Closed like everything else? See the screenshot below:
If you are manually setting up sensors in configuration.yaml, you can ‘most’ of the time state the device class then. There are some times that you have to use customize.yaml. You can always use customize.yaml for any sensor whether it is integration or manual.
