Battery Eliminators
Hello, I have some sensors that use CR123A or CR2 batteries.
Becuase of bugs in their firmware they will drain battery very often.
I found a solution in https://batteryeliminatorstore.com
But each eliminator is $60 per sensor. More expensive than the sensor itself.
I don’t have time to uninstall, update firmware and reinstall or skills to solder anything.
And I have 15 sensors that need a fix.
Are there other solutions out there?
What happens if I simply feed the sensors 5v instead of 3v?
Thanks,
Oscar
A soldering iron and a 5VDC supply
It’ll work twice as good :blush:
I’m sure they have circuit to regulate incoming power so 5v will be OK
A soldering Iron and a 3V supply. Most should be 3.3V tolerant but 5V may be pushing it.
I’m not so sure. Then it might be a sensor eliminator :slight_smile: But you can also add something like this:
https://www.amazon.com/AMS1117-3-3V-Voltage-Regulator-4-5-7V-Output/dp/B074FDLCLB
This will require soldering directly into the sensor. Which is something I don’t feel confortable doing myself.
I wonder if I can get a dummy CR2 battery somewhere and just cram the cables with the dummy inside the sensot
if you’re going to try to “cram the cables in” you still need to somehow really affix the cables… which means soldering.
unless you have shaky hands, why not give soldering a try? it’s really not hard. i’ve taught 12 year olds to do it. the main issue is really if you have a condition where you cannot hold your hands relatively still.
a 3volt adapter should cost about $5. i wouldn’t do the 3v regulator just to then put a 5 volt charge on it… at that point, just get the 3v adapter…
one other thought… if you have a 3d printer it wouldn’t be hard to 3d print a "coin with holes that you could thread the + and - wires through… you could avoid soldering that way…
I like this idea, I think I can design in such a way that the dc step down conveeter is inside the 3d dummy battery.
