Battery empty after 4 days - should be longer?
I need some help with a small project. I am trying to safe battery power. Am running a display that shows different tempartures for today and the next hours/week. It pulls the information from an MQTT broker, which gets its information from HA. HA is actually not involved at all.
The display is refreshed only once per hour after which it goes into deep-sleep. From other sources I read that this should last for months. I only seem to be able to get the battery last for 4 days max.
See the graph:
The hardware:
Board: HUZZAH Featherboard ESP-wroom-32ESP
Battery:waveshare 3700mAh 3,7v
Screen: Waveshare e-paper 7.5 inch v2
This is the script. Is there anyone that can take a look at this what I am doing wrong why the battery is drained so quickly.
esphome:
  platform: ESP32
  board: featheresp32
  on_boot:
    priority: -100
    then:
      - wait_until:
          mqtt.connected:
      # Wait for some valid temp data
      - wait_until:
          sensor.in_range:
            above: -460
      - delay: 1s
      - component.update: sntp_time
      - component.update: voltage
      # Give some time to get the rest of the mqtt data
      - component.update: epaper_display
      # Wait for display update cycle
      - delay: 6s
      # Go back to sleep once display has updated
      # - deep_sleep.enter: deep_sleep_1
      - if:
          condition:
            binary_sensor.is_on: ota_mode
          then:
            - deep_sleep.prevent: deep_sleep_1
          else:
logger:
  level: DEBUG
# api:
#  encryption:
#    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
mqtt:
  broker: 192.168.10.2
  username: !secret mqtt_login
  password: !secret mqtt_password
binary_sensor:
    internal: True
    on_state:
      if:
        condition:
        then:
    internal: True
    on_state:
      if:
        condition:
          binary_sensor.is_off: ota_mode
        then:
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.10.14
    gateway: 192.168.10.1
    subnet: 255.255.255.0
    dns1: 192.168.10.1
  fast_connect: True
  power_save_mode: HIGH
deep_sleep:
  run_duration: 60s
  sleep_duration: 60min
font:
  - file: "fonts/AcuminPro-Medium.ttf"
    glyphs: [' ', '°', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'C', '.', '-']
  - file: "fonts/AcuminPro-Light.ttf"
    glyphs: [' ', '°', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'C', '.', 'm', 'i', 'n', 'a', 'x', ':', '/', '%', 'r', '-']
  - file: 'fonts/materialdesignicons-webfont.ttf'
    glyphs: &mdi-weather-glyphs
      - "\U000F0590" # mdi-weather-cloudy
      - "\U000F0F2F" # mdi-weather-cloudy-alert
      - "\U000F0E6E" # mdi-weather-cloudy-arrow-right
      - "\U000F0591" # mdi-weather-fog
      - "\U000F0592" # mdi-weather-hail
      - "\U000F0F30" # mdi-weather-hazy
      - "\U000F0898" # mdi-weather-hurricane
      - "\U000F0593" # mdi-weather-lightning
      - "\U000F067E" # mdi-weather-lightning-rainy
      - "\U000F0594" # mdi-weather-night
      - "\U000F0F31" # mdi-weather-night-partly-cloudy
      - "\U000F0595" # mdi-weather-partly-cloudy
      - "\U000F0F32" # mdi-weather-partly-lightning
      - "\U000F0F33" # mdi-weather-partly-rainy
      - "\U000F0F34" # mdi-weather-partly-snowy
      - "\U000F0F35" # mdi-weather-partly-snowy-rainy
      - "\U000F0596" # mdi-weather-pouring
      - "\U000F0597" # mdi-weather-rainy
      - "\U000F0598" # mdi-weather-snowy
      - "\U000F0F36" # mdi-weather-snowy-heavy
      - "\U000F067F" # mdi-weather-snowy-rainy
      - "\U000F0599" # mdi-weather-sunny
      - "\U000F0F37" # mdi-weather-sunny-alert
      - "\U000F14E4" # mdi-weather-sunny-off
      - "\U000F059A" # mdi-weather-sunset
      - "\U000F059B" # mdi-weather-sunset-down
      - "\U000F059C" # mdi-weather-sunset-up
      - "\U000F0F38" # mdi-weather-tornado
      - "\U000F059D" # mdi-weather-windy
      - "\U000F059E" # mdi-weather-windy-variant
      - "\U000F10C2" # mdi-thermometer-high
      - "\U000F10C3" # mdi-thermometer-low
      - "\U000F0E01" # mdi-thermometer-alert
      - "\U000F054B" # mdi-umbrella-outline
      - "\U000F0F29" # mdi-snowflake-alert
      - "\U000F12A3" # mdi-battery-high
      - "\U000F12A2" # mdi-battery-medium
      - "\U000F12A1" # mdi-battery-low
    glyphs: *mdi-weather-glyphs
color:
  - id: color_white
    red: 0%
    green: 0%
    blue: 0%
    white: 0%
time:
  - platform: sntp
text_sensor:
  - platform: mqtt_subscribe
    internal: True
    topic: homeassistant/prevent_deep_sleep_temp_sign
    on_value:
      then:
        - binary_sensor.template.publish:
            state: !lambda 'return id(ota_mode_payload).state == "on";'
    topic: homeassistant/sensor/weathertoday/state
    topic: homeassistant/sensor/weathertoday/month
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertoday/icon
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertodayhourly/hour1
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertodayhourly/icon1
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertodayhourly/hour2
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertodayhourly/icon2
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertodayhourly/hour3
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertodayhourly/icon3
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertodayhourly/hour4
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertodayhourly/icon4
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertomorrow/day
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertomorrow/month
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weathertomorrow/icon
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weatherdays/day1
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weatherdays/icon1
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weatherdays/day2
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weatherdays/icon2
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weatherdays/day3
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weatherdays/icon3
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weatherdays/day4
    internal: True
    filters:
      - substitute:
    topic: homeassistant/sensor/weatherdays/icon4
    internal: True
    filters:
      - substitute:
  - platform: adc
    pin: A13
    name: "ESP32 Battery Voltage"
    attenuation: 11db
    filters:
      - multiply: 2
    internal: True
    topic: homeassistant/sensor/weathertoday/date
    internal: True
    topic: homeassistant/sensor/weathertoday/temperature
    internal: True
    topic: homeassistant/sensor/weathertoday/lowtemp
    internal: True
    topic: homeassistant/sensor/weathertoday/hightemp
    internal: True
    topic: homeassistant/sensor/weathertoday/percipitation
    internal: True
    topic: homeassistant/sensor/weathertodayhourly/temp1
    internal: True
    topic: homeassistant/sensor/weathertodayhourly/rain1
    internal: True
    topic: homeassistant/sensor/weathertodayhourly/temp2
    internal: True
    topic: homeassistant/sensor/weathertodayhourly/rain2
    internal: True
    topic: homeassistant/sensor/weathertodayhourly/temp3
    internal: True
    topic: homeassistant/sensor/weathertodayhourly/rain3
    internal: True
    topic: homeassistant/sensor/weathertodayhourly/temp4
    internal: True
    topic: homeassistant/sensor/weathertodayhourly/rain4
    internal: True
    topic: homeassistant/sensor/weathertomorrow/state
    internal: True
    topic: homeassistant/sensor/weathertomorrow/date
    internal: True
    topic: homeassistant/sensor/weathertomorrow/lowtemp
    internal: True
    topic: homeassistant/sensor/weathertomorrow/percipitation
    internal: True
    topic: homeassistant/sensor/weatherdays/hightemp1
    internal: True
    topic: homeassistant/sensor/weatherdays/lowtemp1
    internal: True
    topic: homeassistant/sensor/weatherdays/rain1
    internal: True
    topic: homeassistant/sensor/weatherdays/hightemp2
    internal: True
    topic: homeassistant/sensor/weatherdays/lowtemp2
    internal: True
    topic: homeassistant/sensor/weatherdays/rain2
    internal: True
    topic: homeassistant/sensor/weatherdays/hightemp3
    internal: True
    topic: homeassistant/sensor/weatherdays/lowtemp3
    internal: True
    topic: homeassistant/sensor/weatherdays/rain3
    internal: True
    topic: homeassistant/sensor/weatherdays/hightemp4
    internal: True
    topic: homeassistant/sensor/weatherdays/lowtemp4
    internal: True
    topic: homeassistant/sensor/weatherdays/rain4
spi:
  clk_pin: 5
  mosi_pin: 18
display:
  - platform: waveshare_epaper
    cs_pin: 22
    dc_pin: 23
    busy_pin: 32
    reset_pin: 21
    model: 7.50inV2
    update_interval: never
    reset_duration: 2ms
    rotation: 270°
    lambda: |-
      it.filled_rectangle(0, 395, 480, 2);
      it.filled_rectangle(118, 240, 2, 98);
      it.filled_rectangle(236, 240, 2, 98);
      it.filled_rectangle(354, 240, 2, 98);
      it.filled_rectangle(118, 600, 2, 125);
      it.filled_rectangle(236, 600, 2, 125);
      it.filled_rectangle(354, 600, 2, 125);
      // Map weather states to MDI characters.
      std::map<std::string, std::string> weather_icon_map
          {"cloudy", "\U000F0590"},
          {"cloudy-alert", "\U000F0F2F"},
          {"cloudy-arrow-right", "\U000F0E6E"},
          {"fog", "\U000F0591"},
          {"hail", "\U000F0592"},
          {"hazy", "\U000F0F30"},
          {"hurricane", "\U000F0898"},
          {"lightning", "\U000F0593"},
          {"lightning-rainy", "\U000F067E"},
          {"night", "\U000F0594"},
          {"clear-night", "\U000F0594"},
          {"night-partly-cloudy", "\U000F0F31"},
          {"partlycloudy", "\U000F0595"},
          {"partly-lightning", "\U000F0F32"},
          {"partly-rainy", "\U000F0F33"},
          {"partly-snowy", "\U000F0F34"},
          {"partly-snowy-rainy", "\U000F0F35"},
          {"pouring", "\U000F0596"},
          {"rainy", "\U000F0597"},
          {"snowy", "\U000F0598"},
          {"snowy-heavy", "\U000F0F36"},
          {"snowy-rainy", "\U000F067F"},
          {"sunny", "\U000F0599"},
          {"sunny-alert", "\U000F0F37"},
          {"sunny-off", "\U000F14E4"},
          {"sunset", "\U000F059A"},
          {"sunset-down", "\U000F059B"},
          {"sunset-up", "\U000F059C"},
          {"tornado", "\U000F0F38"},
          {"windy", "\U000F059D"},
          {"windy-variant", "\U000F059E"},
          {"low-temperature", "\U000F10C3"},
          {"high-temperature", "\U000F10C2"},
          {"alert-temperature", "\U000F0E01"},
          {"umbrella", "\U000F054B"},
          {"alert-low-temperature", "\U000F0F29"},
      // Today Date Section
      it.print(85.5, 25, id(tm24), TextAlign::TOP_CENTER, "TODAY");
      it.printf(85.5, 90, id(tm90), TextAlign::CENTER, "%.0f", id(datetoday).state);
      it.printf(85.5, 120, id(tm24), TextAlign::TOP_CENTER, "%s", id(monttoday).state.c_str());
      // Today Temperature & Description
      it.printf(260, 90, id(im90), TextAlign::CENTER_RIGHT, weather_icon_map[id(icontoday).state.c_str()].c_str());
      it.printf(260, 90, id(tm90), TextAlign::CENTER_LEFT, "%.1f°", id(temptoday).state);
      it.printf(295, 135, id(tm24), TextAlign::TOP_CENTER, "%s", id(desctoday).state.c_str());
      // Today Rain
      it.printf(210.50, 170, id(tm24), TextAlign::TOP_RIGHT, "%.0f%%", id(perctoday).state);
      it.print(210.50, 168, id(im24), TextAlign::TOP_LEFT, "\U000F054B");
      // Today Low Temperature
      it.printf(295, 170, id(tl24), TextAlign::TOP_RIGHT, "%.1f°", id(lowttoday).state);
      if(id(lowttoday).state < -5 ) {
        it.print(295, 168, id(im24), TextAlign::TOP_LEFT, "\U000F0F29");
      } else {
        it.print(295, 168, id(im24), TextAlign::TOP_LEFT, "\U000F10C3");
      // Today High Temperature
      it.printf(379.50, 170, id(tm24), TextAlign::TOP_RIGHT, "%.1f°", id(hightoday).state);
      if(id(hightoday).state > 34) {
        it.print(379.50, 168, id(im24), TextAlign::TOP_LEFT, "\U000F0E01");
      } else {
        it.print(379.50, 168, id(im24), TextAlign::TOP_LEFT, "\U000F10C2");
      // Today hour 1
      it.printf(59, 250, id(tm24), TextAlign::TOP_CENTER, "%s", id(hrtime1).state.c_str());
      it.printf(49, 275, id(im40), TextAlign::TOP_RIGHT, weather_icon_map[id(hricon1).state.c_str()].c_str());
      it.printf(49, 295, id(tm24), TextAlign::CENTER_LEFT, "%.1f°", id(hrtemp1).state);
      it.print(46, 315, id(im20), TextAlign::TOP_RIGHT, "\U000F054B");
      it.printf(46, 328, id(tm24), TextAlign::CENTER_LEFT, "%.0f%%", id(hrrain1).state);
      // Today hour 2
      it.printf(177, 250, id(tm24), TextAlign::TOP_CENTER, "%s", id(hrtime2).state.c_str());
      it.printf(167, 275, id(im40), TextAlign::TOP_RIGHT, weather_icon_map[id(hricon2).state.c_str()].c_str());
      it.printf(167, 295, id(tm24), TextAlign::CENTER_LEFT, "%.1f°", id(hrtemp2).state);
      it.print(164, 315, id(im20), TextAlign::TOP_RIGHT, "\U000F054B");
      it.printf(164, 328, id(tm24), TextAlign::CENTER_LEFT, "%.0f%%", id(hrrain2).state);
      // Today hour 3
      it.printf(295, 250, id(tm24), TextAlign::TOP_CENTER, "%s", id(hrtime3).state.c_str());
      it.printf(285, 275, id(im40), TextAlign::TOP_RIGHT, "%s", weather_icon_map[id(hricon3).state.c_str()].c_str());
      it.printf(285, 295, id(tm24), TextAlign::CENTER_LEFT, "%.1f°", id(hrtemp3).state);
      it.print(286, 315, id(im20), TextAlign::TOP_RIGHT, "\U000F054B");
      it.printf(286, 328, id(tm24), TextAlign::CENTER_LEFT, "%.0f%%", id(hrrain3).state);
      // Today hour 4
      it.printf(413, 250, id(tm24), TextAlign::TOP_CENTER, "%s", id(hrtime4).state.c_str());
      it.printf(403, 275, id(im40), TextAlign::TOP_RIGHT, "%s", weather_icon_map[id(hricon4).state.c_str()].c_str());
      it.printf(403, 295, id(tm24), TextAlign::CENTER_LEFT, "%.1f°", id(hrtemp4).state);
      it.print(404, 315, id(im20), TextAlign::TOP_RIGHT, "\U000F054B");
      it.printf(404, 328, id(tm24), TextAlign::CENTER_LEFT, "%.0f%%", id(hrrain4).state);
      // Tomorrow Date Section
      it.printf(85.5, 420, id(tm24), TextAlign::TOP_CENTER, "%s", id(daytom).state.c_str());
      it.printf(85.5, 485, id(tm90), TextAlign::CENTER, "%.0f", id(datetom).state);
      it.printf(85.5, 515, id(tm24), TextAlign::TOP_CENTER, "%s", id(monttom).state.c_str());
      // Tomorrow Temperature & Rain
      it.printf(280, 485, id(im90), TextAlign::CENTER_RIGHT, weather_icon_map[id(icontom).state.c_str()].c_str());
      it.printf(280, 485, id(tm60), TextAlign::BOTTOM_LEFT, "%.1f°", id(hightom).state);
      it.printf(290, 485, id(tl60), TextAlign::TOP_LEFT, "%.1f°", id(lowtom).state);
      it.printf(295, 540, id(tm24), TextAlign::TOP_RIGHT, "%.0f%%", id(perctom).state);
      it.print(295, 540, id(im24), TextAlign::TOP_LEFT, "\U000F054B");
      // Forecast Day 2
      it.printf(59, 610, id(tm24), TextAlign::TOP_CENTER, "%s.", id(day1days).state.c_str());
      it.printf(54, 640, id(im40), TextAlign::TOP_RIGHT, "%s", weather_icon_map[id(icon1days).state.c_str()].c_str());
      it.printf(54, 650, id(tm24), TextAlign::CENTER_LEFT, "%.1f°", id(high1days).state);
      it.printf(54, 675, id(tl24), TextAlign::CENTER_LEFT, "%.1f°", id(low1days).state);
      it.print(44, 695, id(im20), TextAlign::TOP_RIGHT, "\U000F054B");
      it.printf(44, 708, id(tm24), TextAlign::CENTER_LEFT, "%.0f%%", id(rain1days).state);
      // Forecast Day 3
      it.printf(177, 610, id(tm24), TextAlign::TOP_CENTER, "%s.", id(day2days).state.c_str());
      it.printf(172, 640, id(im40), TextAlign::TOP_RIGHT, "%s", weather_icon_map[id(icon2days).state.c_str()].c_str());
      it.printf(172, 650, id(tm24), TextAlign::CENTER_LEFT, "%.1f°", id(high2days).state);
      it.printf(172, 675, id(tl24), TextAlign::CENTER_LEFT, "%.1f°", id(low2days).state);
      it.print(162, 695, id(im20), TextAlign::TOP_RIGHT, "\U000F054B");
      it.printf(162, 708, id(tm24), TextAlign::CENTER_LEFT, "%.0f%%", id(rain2days).state);
      // Forecast Day 4
      it.printf(295, 610, id(tm24), TextAlign::TOP_CENTER, "%s.", id(day3days).state.c_str());
      it.printf(290, 640, id(im40), TextAlign::TOP_RIGHT, "%s", weather_icon_map[id(icon3days).state.c_str()].c_str());
      it.printf(290, 650, id(tm24), TextAlign::CENTER_LEFT, "%.1f°", id(high3days).state);
      it.printf(290, 675, id(tl24), TextAlign::CENTER_LEFT, "%.1f°", id(low3days).state);
      it.print(285, 695, id(im20), TextAlign::TOP_RIGHT, "\U000F054B");
      it.printf(285, 708, id(tm24), TextAlign::CENTER_LEFT, "%.0f%%", id(rain3days).state);
      // Forecast Day 5
      it.printf(413, 610, id(tm24), TextAlign::TOP_CENTER, "%s.", id(day4days).state.c_str());
      it.printf(403, 640, id(im40), TextAlign::TOP_RIGHT, "%s", weather_icon_map[id(icon4days).state.c_str()].c_str());
      it.printf(403, 650, id(tm24), TextAlign::CENTER_LEFT, "%.1f°", id(high4days).state);
      it.printf(403, 675, id(tl24), TextAlign::CENTER_LEFT, "%.1f°", id(low4days).state);
      it.print(398, 695, id(im20), TextAlign::TOP_RIGHT, "\U000F054B");
      it.printf(398, 708, id(tm24), TextAlign::CENTER_LEFT, "%.0f%%", id(rain4days).state);
      // Battery Status
      //float volt = (id(voltage).state - 3.02) * 100;
      //if(volt > 60) {
      //  it.printf(10, 785, id(im20), TextAlign::BOTTOM_LEFT, "\U000F12A3");
      //} else if (volt > 30) {
      //  it.printf(10, 785, id(im20), TextAlign::BOTTOM_LEFT, "\U000F12A2");
      //} else {
      //  it.printf(10, 785, id(im20), TextAlign::BOTTOM_LEFT, "\U000F12A1");
      //it.printf(30, 780, id(tm12), TextAlign::BOTTOM_LEFT, "%.0f%%", volt);
      if(id(ota_mode).state) {
        it.filled_rectangle (0, 765, 520, 30);
        it.print(255, 787, id(tm12), color_white, TextAlign::BOTTOM_CENTER, "OTA MODE ON");
        // Battery Status
        float volt = (id(voltage).state - 2.93) * 100;
        if(volt > 60) {
          it.printf(10, 787, id(im20), color_white,TextAlign::BOTTOM_LEFT,   "\U000F12A3");
          it.printf(10, 787, id(im20), color_white, TextAlign::BOTTOM_LEFT, "\U000F12A2");
        } else {
          it.printf(10, 787, id(im20), color_white,TextAlign::BOTTOM_LEFT,  "\U000F12A1");
        it.printf(30, 785, id(tm12), color_white, TextAlign::BOTTOM_LEFT,  "%.0f%%", volt);
        it.strftime(455, 785, id(tm12), color_white, TextAlign::BOTTOM_RIGHT, "Last updated: %H:%M", id(sntp_time).now());
      } else {
        // Battery Status
        if(volt > 60) {
          it.printf(10, 787, id(im20), TextAlign::BOTTOM_LEFT, "\U000F12A3");
          it.printf(10, 787, id(im20), TextAlign::BOTTOM_LEFT, "\U000F12A2");
        } else {
          it.printf(10, 787, id(im20), TextAlign::BOTTOM_LEFT, "\U000F12A1");
        it.printf(30, 785, id(tm12), TextAlign::BOTTOM_LEFT, "%.0f%%", volt);
        it.strftime(455, 785, id(tm12), TextAlign::BOTTOM_RIGHT, "Last updated: %H:%M", id(sntp_time).now());
      // Last Update Section
      // it.strftime(455, 785, id(tm12), TextAlign::BOTTOM_RIGHT, "last updated: %H:%M", id(sntp_time).now());
I have a second display showing the same issues. Help would be greatly appreciated.
I’m learning this stuff too, but here’s some things you could check.
Is the ESP optimised for deep sleep? I’m not familiar with that one. This vid is quite good.
Do the sensors/screen consume power during deep sleep? Are they battery powered? Again I’m not sure about his this works.
Do you need it on overnight? I do hourly during the day then sleep from 9pm to 5am for one of my projects.
Is your “sleep when updated” effective? Ie does it go to sleep after ~20sec rather than 60sec? I use the uptime sensor to keep an eye on this.
Do you have a voltage divider for battery level measurement? Do you know what the current draw is for that?
Thank you @Mahko_Mahko. That video was very clear and I now understand that my HUZZAH board is the problem. With a deep sleep consumption of 7000µA. Which is the highest of his test.
So I will be looking for a different board. I will keep posting here with the result.
