Battery integration in Energy Dashboard not configuring
I have studied this Energy dashboard and Solax grid and battery integration
in trying to resolve my problem with setting up the Battery integration in the Energy Dashboard.
I have tried countless ways of configuring the sensor entities and thought I understood how it works but cannot get the battery discharge entity to show as valid in the battery integration when I try to add the battery system.
Here is my relevant code:
      battry_ch_rate:
        friendly_name: "Battery Charge Rate"
        value_template: >-
            {% if (states.sensor.solaxBatt.attributes['data'][0]['batList'][0]['dataDict'][2].value | float ) > 0 %}
            {{ (states.sensor.solaxBatt.attributes['data'][0]['batList'][0]['dataDict'][2].value | float | abs) }}
            {% else %}
            0
            {% endif %}
        device_class: power
        unit_of_measurement: 'W'
      battry_disch_rate:
        friendly_name: "Battery Discharge Rate"
        value_template: >-
            {% if (states.sensor.solaxBatt.attributes['data'][0]['batList'][0]['dataDict'][2].value | float )  < 0 %}
            {% else %}
            0
            {% endif %}
        device_class: power
  - platform: integration
    name: Battery Ch Energy
    source: sensor.battry_ch_rate
    unit_prefix: k
    unit_time: h
    round: 2
    method: left
    name: Battery Disch Energy
    source: sensor.battry_disch_rate
    unit_prefix: k
    unit_time: h
    round: 2
    method: left
utility_meter:
#   battery_ch_energy:
#     source: sensor.battry_ch_rate
#     cycle: daily
#   battery_disch_energy:
#     source: sensor.battry_disch_rate
#     cycle: daily
****customize.yaml    ****
sensor.battery_ch_energy:
  #friendly_name: Battery Charge Energy
  device_class: energy
  state_class: total_increasing
  unit_of_measurement: kWh
  last_reset: '1970-01-01T00:00:00+00:00'
sensor.battery_disch_energy:
  #friendly_name: Battery Discharge Energy
The entities look correct:
Battery Ch Energy
2320.26	state_class: total
friendly_name: Battery Ch Energy
last_reset: 1970-01-01T00:00:00+00:00
2414.34	state_class: total
friendly_name: Battery Disch Energy
as do the source entities:
Battery Charge Rate
513.0	unit_of_measurement: W
device_class: power
friendly_name: Battery Charge Rate
device_class: power
friendly_name: Battery Discharge Rate
Any help in resolving this would be much appreciated.
This was resolved by changing the entity names. Strange that there is no way to logically troubleshoot such a situation. Solutions by guesswork.
