Hi Daniel & Waly
Wishing both you and your loved ones the very best for 2024!
I finally remembered to take these snapshots of the log:
Before starting to charge (rebooted though)
--------- beginning of main
30-12 21:40:44.349 1708 1708 D SensorReceiver: Received intent: android.intent.action.SCREEN_ON
30-12 21:40:44.352 1708 1708 D SensorReceiver: Sensor is_interactive corresponding to received event android.intent.action.SCREEN_ON is disabled, skipping sensors update
30-12 21:40:44.361 1708 1708 D ButtonWidget: Broadcast received:
30-12 21:40:44.361 1708 1708 D ButtonWidget: Broadcast action: android.intent.action.SCREEN_ON
30-12 21:40:44.361 1708 1708 D ButtonWidget: AppWidgetId: -1
30-12 21:40:44.375 1708 1708 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
30-12 21:40:44.386 1708 1708 D MediaPlayCtrlsWidget: Broadcast received:
30-12 21:40:44.386 1708 1708 D MediaPlayCtrlsWidget: Broadcast action: android.intent.action.SCREEN_ON
30-12 21:40:44.386 1708 1708 D MediaPlayCtrlsWidget: AppWidgetId: -1
30-12 21:40:44.391 1708 1708 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
30-12 21:40:44.414 1708 1708 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
30-12 21:40:44.560 1708 1708 D SensorReceiver: Received intent: android.intent.action.SCREEN_OFF
30-12 21:40:44.564 1708 1708 D SensorReceiver: Sensor is_interactive corresponding to received event android.intent.action.SCREEN_OFF is disabled, skipping sensors update
30-12 21:40:44.565 1708 1708 D ButtonWidget: Broadcast received:
30-12 21:40:44.565 1708 1708 D ButtonWidget: Broadcast action: android.intent.action.SCREEN_OFF
30-12 21:40:44.565 1708 1708 D ButtonWidget: AppWidgetId: -1
30-12 21:40:44.568 1708 1708 D MediaPlayCtrlsWidget: Broadcast received:
30-12 21:40:44.568 1708 1708 D MediaPlayCtrlsWidget: Broadcast action: android.intent.action.SCREEN_OFF
30-12 21:40:44.568 1708 1708 D MediaPlayCtrlsWidget: AppWidgetId: -1
30-12 21:40:49.697 1708 1708 I BeaconManager: BeaconManager started up on pid 1708 named 'io.homeassistant.companion.android.minimal' for application package 'io.homeassistant.companion.android.minimal'. isMainProcess=true
30-12 21:40:50.619 1708 1857 I SensorReceiver: Sensor updates and sync completed
30-12 21:44:11.981 1708 1708 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@ea04ea
30-12 21:44:12.111 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsetsAnimationController;->getHiddenStateInsets()Landroid/graphics/Insets; (blacklist, linking, denied)
30-12 21:44:12.112 1708 1708 W android.minima: Accessing hidden method Landroid/view/View;->getWindowInsetsController()Landroid/view/WindowInsetsController; (blacklist, linking, denied)
30-12 21:44:12.120 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsetsAnimationController;->getShownStateInsets()Landroid/graphics/Insets; (blacklist, linking, denied)
30-12 21:44:12.121 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsetsAnimationController;->getCurrentInsets()Landroid/graphics/Insets; (blacklist, linking, denied)
30-12 21:44:12.330 1708 1708 I SurfaceFactory: [static] sSurfaceFactory = com.mediatek.view.impl.SurfaceFactoryImpl@84e8ea2
30-12 21:44:12.488 1708 1708 W android.minima: Class androidx.compose.runtime.snapshots.SnapshotStateMap failed lock verification and will run slower.
30-12 21:44:12.489 1708 1708 W android.minima: Common causes for lock verification issues are non-optimized dex code
30-12 21:44:12.489 1708 1708 W android.minima: and incorrect proguard optimizations.
30-12 21:44:12.515 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Type;->ime()I (blacklist, linking, denied)
30-12 21:44:12.520 1708 1708 W android.minima: Accessing hidden method Landroid/graphics/Canvas;->drawPatch(Landroid/graphics/NinePatch;Landroid/graphics/Rect;Landroid/graphics/Paint;)V (greylist-max-o, linking, denied)
30-12 21:44:12.520 1708 1708 W android.minima: Accessing hidden method Landroid/graphics/Canvas;->drawPatch(Landroid/graphics/NinePatch;Landroid/graphics/RectF;Landroid/graphics/Paint;)V (greylist-max-o, linking, denied)
30-12 21:44:12.522 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsetsController;->show(I)V (blacklist, linking, denied)
30-12 21:44:12.526 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsetsController;->hide(I)V (blacklist, linking, denied)
30-12 21:44:12.583 1708 1708 W android.minima: Accessing hidden method Landroid/content/res/Resources$Theme;->getKey()Landroid/content/res/Resources$ThemeKey; (greylist-max-o, reflection, denied)
30-12 21:44:12.661 1708 1708 E GraphicExt: Can't load libboost_ext_fwk
30-12 21:44:12.661 1708 1708 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
30-12 21:44:12.663 1708 3834 I GPUD : @gpudInitialize: successfully initialized with GL, dbg=0 mmdump_dbg=0 mmpath_dbg=0
30-12 21:44:12.704 1708 3834 W Gralloc3: mapper 3.x is not supported
30-12 21:44:12.708 1708 3834 E ion : ioctl c0044901 failed with code -1: Invalid argument
30-12 21:44:12.815 1708 1708 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@40116c3
30-12 21:44:12.843 1708 3844 I System.out: [socket]:check permission begin!
30-12 21:44:13.582 1708 3884 E linker : library "" ("/system/lib64") needed or dlopened by "/system/lib64/vndk-sp-29/libRS_internal.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64:/system/product/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/system/vendor/framework:/system/vendor/app:/system/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand:/apex/com.android.runtime/lib64/bionic:/system/lib64/bootstrap"]
30-12 21:44:13.582 1708 3884 E RenderScript: Failed loading RS driver: dlopen failed: library "" needed or dlopened by "/system/lib64/vndk-sp-29/libRS_internal.so" is not accessible for the namespace "rs"
30-12 21:44:13.582 1708 3884 E RenderScript: Failed to load runtime , loading default
30-12 21:44:13.695 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:13.708 1708 3889 I chatty : uid=10187(io.homeassistant.companion.android.minimal) Chrome_InProcGp identical 2 lines
30-12 21:44:13.729 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:13.785 1708 3889 W AudioCapabilities: Unsupported mime audio/x-adpcm-ms
30-12 21:44:13.785 1708 3889 W AudioCapabilities: Unsupported mime audio/x-adpcm-dvi-ima
30-12 21:44:13.785 1708 3889 W AudioCapabilities: Unsupported mime audio/alac
30-12 21:44:13.785 1708 3889 W AudioCapabilities: Unsupported mime audio/ape
30-12 21:44:13.786 1708 3889 W AudioCapabilities: Unsupported mime audio/x-ms-wma
30-12 21:44:13.795 1708 3889 W VideoCapabilities: Unrecognized profile/level 1/32 for video/mp4v-es
30-12 21:44:13.795 1708 3889 W VideoCapabilities: Unrecognized profile/level 32768/2 for video/mp4v-es
30-12 21:44:13.795 1708 3889 W VideoCapabilities: Unrecognized profile/level 32768/64 for video/mp4v-es
30-12 21:44:13.799 1708 3889 W VideoCapabilities: Unsupported mime video/x-ms-wmv
30-12 21:44:13.801 1708 3889 W VideoCapabilities: Unsupported mime video/xvid
30-12 21:44:13.806 1708 3889 W VideoCapabilities: Unrecognized profile/level 1/32 for video/mp4v-es
30-12 21:44:13.859 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:13.876 1708 3889 I chatty : uid=10187(io.homeassistant.companion.android.minimal) Chrome_InProcGp identical 4 lines
30-12 21:44:13.877 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:14.061 1708 1708 I Choreographer: Skipped 74 frames! The application may be doing too much work on its main thread.
30-12 21:44:14.097 1708 1708 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
30-12 21:44:14.166 1708 3834 I OpenGLRenderer: Davey! duration=1342ms; Flags=1, IntendedVsync=241163286472, Vsync=242396619830, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=242403157091, AnimationStart=242403206629, PerformTraversalsStart=242406711629, DrawStart=242445320783, SyncQueued=242452266091, SyncStart=242454165168, IssueDrawCommandsStart=242454365552, SwapBuffers=242505804475, FrameCompleted=242507535783, DequeueBufferDuration=0, QueueBufferDuration=1033000,
30-12 21:44:14.386 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:14.393 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:14.436 1708 1708 E WebviewActivity: onReceivedHttpError: 404 : Not Found for: http://172.16.0.4:8123/local/ThemeOverride.js
30-12 21:44:14.496 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:14.881 1708 1857 I WebViewPresenterImpl: Found color -16537100.
30-12 21:44:14.883 1708 1857 I WebViewPresenterImpl: Found color -328966.
30-12 21:44:21.767 1708 1857 I WebViewPresenterImpl: Found color -15720924.
30-12 21:44:21.768 1708 1857 I WebViewPresenterImpl: Found color -15658735.
30-12 21:44:23.481 1708 1708 E WebviewActivity: onReceivedHttpError: 404 : Not Found for: http://172.16.0.4:8123/custom_components/webrtc/www/webrtc-camera.js
30-12 21:44:23.510 1708 1708 E WebviewActivity: onReceivedHttpError: 404 : Not Found for: http://172.16.0.4:8123/config-template-card.js
30-12 21:44:24.822 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:24.828 1708 3889 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
30-12 21:44:43.472 1708 1745 I android.minima: NativeAlloc concurrent copying GC freed 59587(2575KB) AllocSpace objects, 6(264KB) LOS objects, 47% free, 6663KB/12MB, paused 235us total 166.381ms
30-12 21:44:45.637 1708 1708 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@cb96665
30-12 21:44:45.910 1708 1708 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
30-12 21:44:46.423 1708 3916 I SensorReceiver: Sensor updates and sync completed
30-12 21:44:56.830 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Builder;->setVisible(IZ)Landroid/view/WindowInsets$Builder; (blacklist, linking, denied)
30-12 21:44:56.830 1708 1708 W android.minima: Accessing hidden method Landroid/view/Window;->getInsetsController()Landroid/view/WindowInsetsController; (blacklist, linking, denied)
30-12 21:44:56.831 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsets;->isVisible(I)Z (blacklist, linking, denied)
30-12 21:44:56.832 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsets;->getInsets(I)Landroid/graphics/Insets; (blacklist, linking, denied)
30-12 21:44:56.832 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Builder;->setInsets(ILandroid/graphics/Insets;)Landroid/view/WindowInsets$Builder; (blacklist, linking, denied)
30-12 21:44:56.833 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Type;->systemGestures()I (blacklist, linking, denied)
30-12 21:44:56.833 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Type;->mandatorySystemGestures()I (blacklist, linking, denied)
30-12 21:44:56.834 1708 1708 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Type;->tappableElement()I (blacklist, linking, denied)
Some time later, still while charging but the state of the sensor has not been updated until I wake the screen to get the log:
30-12 22:45:10.391 1708 1745 W android.minima: Reducing the number of considered missed Gc histogram windows from 355 to 100
30-12 22:49:32.231 1708 1708 I Choreographer: Skipped 33 frames! The application may be doing too much work on its main thread.
30-12 22:49:32.240 1708 1708 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
30-12 22:49:32.701 1708 4884 I System.out: [socket]:check permission begin!
30-12 22:49:34.084 1708 4669 I WebViewPresenterImpl: Found color -15720924.
30-12 22:49:34.110 1708 4669 I WebViewPresenterImpl: Found color -15658735.
30-12 22:49:39.166 1708 1708 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@24e0864
30-12 22:49:39.292 1708 1708 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
30-12 22:49:39.599 1708 4892 I System.out: [socket]:check permission begin!
30-12 22:49:39.963 1708 4653 I SensorReceiver: Sensor updates and sync completed
I can’t make anything out of it.
EDIT: in the meantime I updated the app to v2023.12.4, already before these logs
