I have an off-grid solar system installed at my house. I have software running on a pi that gets data (Power, Volts, Amps, etc.) from the inverter and writes it to a mySQL database. I have Home Assistant running on a separate pi reading the data from the mySQL DB.
My problem is, there are no comms between my battery and my inverter, so the battery State of Charge of the battery is unknown. I only get the voltage of the battery from the inverter, which is not accurate. I am looking for a way to get an accurate SOC from the battery and displaying it in HA.
First option will be if there is a way to read the data from the integrated BMS of the battery. Thus far I have not been successful to do this. I have a Narada 48v 100ah Lithium ion Battery.
Second option is to install a third party Battery Monitor that calculate the state of charge and then sending the info to HA. Is there such a third party Battery Monitor available on the market.
Hi Eric, did you get a solution for this? I am looking for same also
Unfortunately I did not get a solution. I have subsequently sold my Narada battery, so I don’t need this anymore. However, the Narada battery does have a RS-485 port. If you can get or figure out the Modbus configuration, it might be a solution to get the data from the battery.
I will try and assist you of you want to give this a try
salimayoub
(salim Ayoub)
December 27, 2023, 9:37pm
4
i have this problem but with esp and rs485 convert read data but
code :
esphome:
esp32:
board: esp32dev
#////////Enable logging////////////
logger:
level: DEBUG
baud_rate: 0
#//////////////Enable Home Assistant API/////////////
api:
encryption:
key: “”
#//////////OTA/////////////
ota:
password: “”
#//////////WiFi//////////////
wifi:
ssid: Home WiFi
password: Home5642096
#////////////fallback hotspot///////////
ap:
ssid: “Narada-Bms Hotspot”
password: “internetit”
#/////////mqtt//////////
mqtt:
broker: 192.168.101.253
username: bms
password: internetit
#////////uart////////////
captive_portal:
uart:
tx_pin: GPIO19
rx_pin: GPIO18
baud_rate: 9600
data_bits: 8
stop_bits: 1
#////////////modbus//////////
modbus:
flow_control_pin: GPIO4
uart_id: uart_bus
send_wait_time: 500ms
modbus_controller:
address: 0x01 ## address of the ModBUS slave device on the bus
modbus_id: modbus1
command_throttle: 200ms
setup_priority: -10
update_interval: 10s
#//////////////Sensor/////////////////////////
#//////////Cell Volte////////////////////////
platform: modbus_controller
modbus_controller_id: epever
name: “Cell Volte 15”
address: 0x101C
unit_of_measurement: “V” ## for any other unit the value is returned in minutes
register_type: read
value_type: U_WORD
accuracy_decimals: 1
filters:
multiply: 0.01
#///////////////////Cell Temp/////////////////
name: “Cell Temp 0”
register_type: holding
address: 0x101E
unit_of_measurement: “C”
value_type: U_WORD
name: “Cell Temp 1”
address: 0x101F
value_type: FP32
name: “Cell Temp 2”
address: 0x1020
value_type: FP32
name: “Cell Temp 3”
address: 0x1021
value_type: U_WORD
name: “Cell Temp 4”
address: 0x1022
value_type: U_WORD
name: “Cell Temp 5”
address: 0x1023
value_type: U_WORD
name: “Cell Temp 6”
address: 0x1024
value_type: U_WORD
name: “Cell Temp 7”
address: 0x1025
value_type: U_WORD
name: “Cell Temp 8”
address: 0x1026
value_type: U_WORD
name: “Cell Temp 9”
address: 0x1027
value_type: U_WORD
name: “Cell Temp 10”
address: 0x1028
value_type: U_WORD
name: “Cell Temp 11”
address: 0x1029
value_type: U_WORD
name: “Cell Temp 12”
address: 0x102A
value_type: U_WORD
name: “Cell Temp 13”
address: 0x102B
value_type: U_WORD
name: “Cell Temp 14”
address: 0x102C
value_type: U_WORD
name: “Cell Temp 15”
address: 0x102D
value_type: U_WORD
#///////////////Cell D/////////////
name: “Remain Capacity”
address: 0x1001
unit_of_measurement: “AH”
value_type: U_WORD
name: “Average Cell Temp”
address: 0x1002
value_type: U_WORD
address: 0x1000
value_type: U_WORD
address: 0x100C
unit_of_measurement: “#”
value_type: U_WORD
name: “Full Capacity”
address: 0x102E
value_type: U_WORD
name: “Remain Charge Time”
address: 0x102F
unit_of_measurement: “Min”
value_type: U_WORD
name: “Remain Discharge Time”
address: 0x1030
value_type: U_WORD
name: “BMS PCB TEmp”
address: 0x100A
value_type: U_WORD
#////////////Binary Sensor////////////////////
binary_sensor:
entity_category: diagnostic
device_class: problem
register_type: read
address: 0X1003
register_type: read
address: 0X1004
register_type: read
address: 0X1005
register_type: read
address: 0X1006
register_type: read
address: 0X1007
register_type: read
address: 0X1008
register_type: read
address: 0X1009
name: Cell UV State
register_type: read
address: 0X1031
#////////////Text Sensor//////////////////////
#////////////////Switch///////////////////////
#/////////////Number/////////////////////////
#/////////////Output////////////////////////
#/////////////web Server/////////////////////
web_server:
port: 80
auth:
username: admin
