since installing Battery Notes, the device icons in settings > devices are inconsistent:
In this image these two ZHA battery powered devices have been assigned two different icons.
Battery Notes is not really a device so I think it should be relegated to second place. Is there any way to edit this?
regards
Steve
There is a note about this on the GitHub page. According to the developer, HA assigns those icons at random and he hasn’t found a way to control it. You’re right, it’s annoying.
opened 01:31AM - 06 Dec 23 UTC
closed 08:39AM - 06 Dec 23 UTC
### Checklist
- [X] I have filled out the template to the best of my ability.
-… [X] This only contains 1 feature request (if you have multiple feature requests, open one feature request for each feature request).
- [X] This issue is not a duplicate feature request of [previous feature requests](https://github.com/andrew-codechimp/ha-battery-notes/issues?q=is%3Aissue+label%3A%22Feature+Request%22+).
### Is your feature request related to a problem? Please describe.
When a battery note is added for a device, the device's icon changes to the HA Battery Notes icon automatically. There's currently option to change this behaviour.
### Describe the solution you'd like
Having a global(?) setting related to the integration that allows the user to choose to retain the original device icon.
### Describe alternatives you've considered
Accepting this can't be changed :-)
### Additional context
Top entry shows the HA Battery Notes icon, bottom entry shows the original device's icon.
Thanks’ - I updated the GH page with a comment that Unifi does not override my SONOS speaker’s icons where both integrations are active for those devices. Maybe there is a way.
Assign a device class in the UI or in customize, unless they don’t have unique_id assigned…
