Which will trigger automation a number of times. And I do not need that. How can I handle this?
And second question about platform: numeric_state, below:
I was testing my UPS and it went from 25% to 9%. Automation was nat triggered (below 21%). How does “below” work? Should it go exactly from 21% to 20%, or from 21% to lower number? I thought that it should work even if 25% goes to 9%.
If not - all my batteries automation seems to be useless.
According to the documentation for numeric_state trigger, you can use a for to specify a time duration. I believe you can use this to indicate you want the numeric-state to be below 36 for at least 15 minutes before it, qualifies as a valid trigger event.
for:
minutes: 15
In other words, the automation will not be triggered the moment the battery level drops below 36%. The level must fall below 36 and stay below that level for at least 15 minutes before it triggers the automation. Full disclosure: I have not tried for with below so I can’t confirm if it works.
Thanks. Actually, I know about that. But I will need not 10-15 mins. It should be like couple of hours. Isn’t it a bit “bad code”? Will it work fine if I will set 2-3 hours?
May be I am asking silly questions, just wanna be sure that it will not make any harm to system stability.
I know that there are issues with “delay”. That is why I am a bit worried.
I do not know about all xiaomi sensors, but two of them can fluctuate
Can anyone help with second question about platform: numeric_state, below:
