I know there are a million doorbell questions that have been asked. I tried to search, but didn’t see anything that really met my needs. I apologize in advance if I overlooked a thread somewhere, the amount of “noise” on this topic is simply mind-boggling.
I need three video doorbells. In a perfect world, they would all be the same or similar models, at the very least from the same manufacturer. I would like to keep the cost under $200 each, but may be willing to go as high as $300 each if absolutely necessary, or if the additional cost gets me a demonstrably better product/solution.
Two of the doorbells I can provide power to (if necessary) via standard doorbell wiring, or perhaps even PoE if absolutely necessary. If all three of them end up the same battery-powered model, that’s fine as well. They should all connect via WiFi (2.4 or 5, either is fine).
The third one is the problem - there is no existing doorbell wiring, nor is there any way to get wiring there without significant effort (removal of drywall on at least 1 wall and one ceiling (basement is finished)). For this one, I don’t see any way around a battery-powered doorbell, and ideally it would report it’s battery status to HA.
The following features are not needed, but would not disqualify a solution if present: puddle light, two-way audio
Ideally, I would like a downward-facing camera if possible in my price range (and battery powered), like the Ubiquiti pro 4. If this feature is not available in a battery-powered model and/or is well out of my price range, that’s ok - this is just a “nice to have”.
I plan to use all three with Blue Iris and DeepStack, so RTSP with substreams.
Does anyone have any first-hand experience with doorbells that meet these specs and work well?
