Battery powered thermostat to use in Europe
Hey everyone,
Recently I’ve been looking to ‘smart up’ my old rbm thermostat (rbm hp). I only have 2 wires coming out of the wall.
thermostat
I was hoping to use a Z-wave (battery powered) thermostat that uses 868.42MHz, but was unable to find any working with the European frequency. GoControl does have the TBZ48 but I believe it only works using 908.42MHz freq.
Can anyone suggest an alternative, even if not using z-wave?
Will be used in HA (rPi) using either a zooz zwave pen or zigbee cc2531.
Hey,
Thanks for the link. This is exactly what I’m looking for, but it doesn’t seem to be wired. How can you connect it to the Live wire?
I will use a wifi or zwave switch If I was you, controlled by that thermostat thru HA. Then you even can get rid of that cable and put the switch near your heater. :wink:
Hey,
The issue is that I don’t have a C-wire, hence the reason why I was looking for a battery-powered thermostat. Any other suggestion is most welcome :slight_smile:
Thanks!
I have 2 wires coming down, a live and neutral. My gas supplier in the UK provided a Nest Thermostat E which I have been using for approx. 2 years. It has 2 AA batteries behind the cover which is easily removable (opening a remote battery compartment is the same level of difficulty). It then has a wireless thermostat.
I must say, I do not like the way it is cloud based etc, but it has worked well for me. Also, when my WiFi was down I figured out I could set the heating to on/off by pressing the big middle button. Rather easy, at least :slight_smile:
EDIT: Have not yet had to change the batteries.
Hey,
Thanks for the information. @rhyslhardy is your system working with a boiler or heat pump?
