I want to display the Battery sensor of my Laptop exactly like the one from my Phone. With the nice dynamic icon and everything.
Isn’t there a simple solution for this?
My solution works, but now I can not plot the sensor together with other sensors from the Phones.
To fix it by myself, I did the following:
- I created a new template sensor called
inspiron_battery
to display the battery level of thesensor.inspiron_battery_charge_remaining_percentage
sensor as a percentage with an appropriate battery icon based on the battery level. - I added an
icon_template
to theinspiron_battery
sensor to change the icon based on the charging status of the Inspiron using thesensor.inspiron_battery_powerline_status
sensor. - Initially, the
inspiron_battery
sensor was missing the charging icon when the Inspiron was plugged in. - I updated the
icon_template
to use different battery icons based on the battery level and charging status.
sensors:
inspiron_battery:
friendly_name: "Inspiron Battery"
value_template: "{{ states('sensor.inspiron_battery_charge_remaining_percentage') }}%"
device_class: battery
icon_template: >-
{% set battery_level = states('sensor.inspiron_battery_charge_remaining_percentage') | int %}
{% set charging_status = states('sensor.inspiron_battery_powerline_status') %}
{% if charging_status == 'Online' %}
{% if battery_level == 100 %}
mdi:battery-charging-100
{% elif battery_level >= 95 %}
mdi:battery-charging-90
{% elif battery_level >= 85 %}
mdi:battery-charging-80
{% elif battery_level >= 75 %}
mdi:battery-charging-70
{% elif battery_level >= 65 %}
mdi:battery-charging-60
{% elif battery_level >= 55 %}
mdi:battery-charging-50
{% elif battery_level >= 45 %}
mdi:battery-charging-40
{% elif battery_level >= 35 %}
mdi:battery-charging-30
{% elif battery_level >= 25 %}
mdi:battery-charging-20
{% elif battery_level >= 15 %}
{% else %}
mdi:battery-alert
{% endif %}
{% else %}
mdi:battery
mdi:battery-90
mdi:battery-80
mdi:battery-70
mdi:battery-60
mdi:battery-50
mdi:battery-40
mdi:battery-30
mdi:battery-20
mdi:battery-10
{% else %}
mdi:battery-alert
{% endif %}
{% endif %}
