Bauhn (Aldi) 5 way Powerboard AP5W-0624 - sharing configuration
Product description
This is a Bauhn (Aldi) AP5W-0624 It is a 5-outlet powerboard with separate “always on” 2xUSB-A and 2xUSB-C outlets. Purchased in July 2024.
The powerboard incorporates a Tuya CBU module incorporating the BK7231N processor.
To realign for ESPHome use I went straight for the “solder and reprogram” method rather than exploring other software only reprogramming options.
The unit is easy to open with “Triangle” socket screws on the back. The CBU module is fairly accessible to solder on the 5 required wires.
The powerboard also incorporates power monitoring using the BL0942 chip.
Other features of the board are:
  1. Separate relays for each power outlet
  2. Surge protection (indicated by an always on green LED)
  3. Single addressable blue LED
  4. Single momentary push button
  5. Re-settable overload (10A)
https://www.aldi.com.au/special-buys/special-buys-sat-29-june/saturday-detail-wk26/ps/p/5-way-surge-protector-powerboard-with-wi-fi-and-meter-reading/
Pinout
This powerboard incorporates the CBU module
Programming header pinout
Pin Comment
TX1 Transmit (connect to Rx on programmer)
RX1 Receive (connect to Tx on programmer)
3.3v 3.3V
Gnd Ground
CEN Ground to access programming mode
Internal pinout
Pin Function
P22 Push Button
P28 Status LED
P6 Relay #1
P7 Relay #2
P8 Relay #3
P9 Relay #4
P24 Relay #5
TX1 Comms to BL0942
RX1 Comms to BL0942
Button
The setup will turn on plugs 1 to 4 with each short press, then once all plugs are on, turn off plugs 1 to 4 with each short press.
A long press will toggle all plugs on or off.
Basic Configuration
# Bauhn 5 way powerboard with individual socket switchng and BL0942 power monitoring.
# USB sockets are permanently on.
# There is only one controllable LED
substitutions:
  friendly_name: Bauhn Power Board
  relay_restore_mode: RESTORE_DEFAULT_OFF
esphome:
  comment: Bauhn 5 way powerboard with power monitoring
bk72xx:
  board: cbu
globals:
  - id: set_on
    type: "bool"
    restore_value: no
    initial_value: "1"
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  - platform: esphome
    password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Bauhn-5-Way-Power-Board"
    password: "xxxxxxxxxxxxxxxx"
    ap_timeout: 2min
    # Not sure but this device did not attach to my SSID without the ap_timeout set to 2 min WiFi a bit weak?
captive_portal:
text_sensor:
  - platform: libretiny
    version:
switch:
  - platform: gpio
    pin: P6
    icon: mdi:power-socket-au
    restore_mode: ${relay_restore_mode}
  - platform: gpio
    pin: P7
  - platform: gpio
    pin: P8
  - platform: gpio
    pin: P9
  - platform: gpio
    pin: P24
light:
  - platform: status_led
    name: "${friendly_name} Status LED"
#   disabled_by_default: true
    pin:
      inverted: false
      number: P28
binary_sensor:
  - platform: gpio
    pin:
      number: P22
      mode:
        input: true
        pullup: true
      inverted: true
    on_multi_click:
      - timing:
          - ON for at most 0.5s
          - OFF for at least 0.5s
        then:
          lambda: |-
            if ( id(set_on) ) {
              if (! id(relay_1).state  ) {
                id(relay_1).turn_on();
              } else if ( ! id(relay_2).state ) {
                id(relay_2).turn_on();
              } else if ( ! id(relay_3).state ) {
                id(relay_3).turn_on();
              } else if ( ! id(relay_4).state ) {
                id(relay_4).turn_on();
              } else if ( ! id(relay_5).state ) {
                id(relay_5).turn_on();
                id(set_on) = 0;
              } else {
                id(relay_1).turn_off();
                id(relay_2).turn_off();
                id(relay_3).turn_off();
                id(relay_4).turn_off();
                id(relay_5).turn_off();
            } else {
              if ( id(relay_1).state  ) {
              } else if (  id(relay_2).state ) {
              } else if (  id(relay_3).state ) {
              } else if (  id(relay_4).state ) {
              } else if (  id(relay_5).state ) {
                id(set_on) = 1;
              } else {
      - timing:
          - ON for at least 0.5s
          - OFF for at least 0.2s
        then:
          lambda: |-
            if (id(relay_1).state ||
            id(relay_2).state ||
            id(relay_3).state ||
            } else {
uart:
  tx_pin: TX1
  rx_pin: RX1
  baud_rate: 4800
  stop_bits: 1
  - platform: bl0942
    uart_id: uart_bus
    voltage:
    current:
    power:
      filters:
        multiply: -1
    energy:
    frequency:
      name: "${friendly_name} Frequency"
      accuracy_decimals: 2
    update_interval: 10s
Thank you for posting this.
Thanks - I’m keen to get as much stuff locally controlled as possible :slight_smile:
Have you noticed the board suddenly switch off?
I am just now trying to put it to use and it shuts down within an hour of being plugged in.
It’s also not great for range with wifi, I note.
I’ve not experienced anything except the poor WiFi reception. Its powering the TV and ammplifier so I’d notice it turning on/off. What is the actual behavipur you are experiencing?
Actually, I had an incorrect board reference.
bk72xx:
board: generic-bk7231n-qfn32-tuya
Missed that when adapting your YAML.
Now it seems stable with the below. Thanks.
bk72xx:
board: cbu
Thanks for posting this teardown. I’ve also got one and I serial flashed the CBU chip. I’ve found you don’t even have to use the CEN header. I wired up TX, RX, GND and 3.3v. Then I power cycled 3.3v and GND and then was able to flash it.
When it had Tuya firmware the energy monitoring worked, but since using ESPHome I can’t get energy monitoring working. My YAML is the same. Perhaps when I was serial flashing it I accidently bridged the wiring that’s needed for the energy monitoring.
I might crack it open again sometime to swap the chip out with an ESP32-C3 ESP8685-WROOM-06 and double check the wiring.
I’ve never flashed this particular ESP chip. I might get a 3D jig printed which would work with either CBU or ESP8685 chip: Tuya CBU Flashing Jig by TheCleaner | Download free STL model | Printables.com
Good work Ben, but sorry to hear the power monitoring is not working. I’ll check mine sometime to see if it’s still ok, perhaps an ESP update has broken it!
Energy monitoring didn’t work in OpenBeken either. Could be a software issue but more likely to be a hardware issue from what I can best guess.
Just curious if you ever ended up swapping the CBU out with an ESP chip at all? I just ordered some to give it a go, but before I tear it apart was wondering how you managed to remove the CBU if you did do it?
Hey Rob, no I haven’t got around to it yet. I’d likely use a hot air gun, flux, soldering wick and 20mm heat resistant tape. I’d cover the nearby components with the tape, apply flux to CBU and then use the hot air gun to remove it. Then use soldering wick to tidy it up and then apply ESP chip with soldering iron. This video is where I got most of my inspiration
STOP using Tuya! Transplant your ESP8266 100% LOCAL - Tuya-Convert F.0
Thanks for the link, good video. Looks like I need to get myself a hot air station.
