BAXI TXM / RXM 10c OpenTherm thermostat - HA integration
The integration just works ! And I’ve also integrated it into HomeKit.
The only problem is that, so far, I’m not able to change from °F to °C
Hi all,
I am trying to integrate my Baxi RXM in Home Assistant using [GitHub - msvisser/remeha_home: Remeha Home integration for Home Assistant] but I am not able to.
@Rold, How did you get it? I am always getting the username/password error message when trying to setup the integration in Home Assistant.
I have the app installed and running in my phone, I have connection to the thermostat as well there but I am not able to compete the user/pass step in HA.
Any help, please?
Thank you in advance
Hello.
And somebody has tested this?
My idea is to take out the TXM thermostat of my baxi and take the info directly from the rbus.
Any idea?
Hi Rold, sorry looking at the comments I’m not sure if this still works after migrating to the new Baxi App. I’m also interested in adding it to HomeKit, could you please let me know the steps needed to have the thermostat added into homekit through homebridge? I would appreciatte that a lot. Thank you very much!
David
is there any one who can let me know if there is any way to integrate/add the TXM thermostat into Homekit/homebridge? Thank you very much!
Hi there, any update for this integration? it looks like after the update to new app it is not possible to work this…
Any update on this? How can I integrate My Baxi in home assistant? Thank you!
Hi, I am just coming across this thread and am hopeful this gateway GTW-16 might offer an option to remotely connect my older Baxi HT 133 and HT 380 boilers to the TXM/RXM thermostats? Can someone offer links to the parts and info required please?
I also use the Baxi HybridApp and the integration mentioned here does not work.
I sweated a bit and managed to find the various API endpoints to get data from the HybridApp (hybridweb.baxi.it).
Now all that remains is to develop the integration for HA on the example of this one, but I am new to developing for HA and so unless I find a contribution, it will take me a long time…
I have forked the original “remaha” integration and added a number of features. Including hot/cooling mode, a separate water heater entity, a water heater boost function and eco/scheduled modes. Please have a look.
I’m not a developer and this has been a result of:
a) building upon the original integration by msvisser using AI and Cursor
b) Listening in to the new API requests I needed by running the app in Android SDK locally
c) A lot of trial and error.
It works pretty much perfectly for me on my Baxi PLATINUM BC IPLUS V200 INTEGRA
In case anyone needs it, I managed to control everything from Home Assistant using an ESP32.
Here’s the project:
If you have Baxi HybridApp, try this extension for Home Assistant:
