First want to understand what to flash etc. Also what is tasmota etc…
What program/instructions to flash etc.
All input is welcome. Then I keep you in the loop of the progress.
Aim is the arrive in a plug controllable by home assistant.
Like ESP8266 based DIY Smart Plug to Make Your Home Appliances IoT Enabled
You can’t use OTA as you first need to flash it with code enable to this.
As far I’m reading and learning I will:
Solder wires on the ESP module and flash it with firmware like explained in Arduino
Then I will be able to upload further programs with OTA
and make my plug connection with Home assistant.
You can program with,
LUA
ESPhome
Tamotizer
Tuyaconvert
How to make a program? I see that with the original firmware in the plug you can read alos the power consumption.
