OK, I assume you are in North America. I find the control panel in zwavejs2mqtt more intuitive. I run Home Assistant Container so I do not use the addons from Home Assistant Supervised or HaOS.
I attempted to pair the lock again, with the stick about 3 inches away from the lock, but when putting in the pairing code, then pressing the Schlep button and the 0, the button immediately flashes red and I get three beeps. This was after I had gone to Devices, zwave.js and it was looking for a zwave device.
Still could use some help if anyone is able to assist
You need to freshly factory reset the lock before including. The inclusion process must complete within 11 seconds once started. Some people need to have the lock closer to the controller for initial pairing.
What @Prodigyplace said above… fully factory reset it… also is it a brand new lock? I literally spent hours fighting with one of mine until I replaced the batteries. They were listed as being in the 80% range at the time so I didn’t bother… after hours of struggling it paired the first time with the fresh set.
However when I check the configuration I get the following error…
Configuration invalid
Invalid config for [zwave]: does not match regular expression (0x\w\w,\s?){15}0x\w\w for dictionary value @ data['zwave']['network_key']. Got 'd96271b2e8e7b327843cdd41157d1292'. (See /config/configuration.yaml, line 29).
Now that I’ve “read the manual” and it still doesn’t seem to be working, maybe I can get some more help?
I must be blind. I did not see where they put the key in a YAML file. I guess I missed that. i do not even know what type of installation you have, Advice for HaOS and Supervieesd users would be different than Container users.
I like the device control panel in zwavejs2mqtt It connects to the zwavejs Integration in HA just like the zwavejs addon for HaOS & Supervised users does. I also like using the official builds from their developers instead of those generated by HA devs or others in the community.
