I’ve just pushed an update to google play. Let’s try it!
Hello, thank you so much for the update!
I just did some testing after update the application and still doesn’t seem to recognize those beacons correctly.
More specifically, the ‘Advanced parameters’ popup no longer displays an error. However, the registered beacon is not activated as it is still displayed as ‘invalid config’ on the main screen after registration process is completed.
I’ve seen the same symptoms on two Android devices. If there is anything I can do to help analyze the problem, please let me know.
Thank you!
Sorry about that… Let’s try fixed v0.3.25!
It works like a charm! Thanks so much for the update!!
You are welcome!
@Turbo
Can you explain in more detail how the HA part is set?
I am new to HA
just follow the steps
You can teach the HA MQTT part to set the Beacon part
