Bed Presence for ESPHome by Elevated Sensors
Hi @stephenp93
thx for the hint but sadly this doesnt work.
I think you cant remove things from other packages, error:
INFO ESPHome 2025.10.4
INFO Reading configuration /config/esphome/schlafzimmer-bed-presence.yaml...
INFO Updating https://github.com/ElevatedSensors/sensor-configs@main
Failed config
sensor.unknown: [source /config/esphome/common/devices/bed_presence_mk1.yaml:57]
  Source for removal of ID 'uptime_sensor' was not found.
  id: !remove uptime_sensor
Sadly, that does’nt work for all sensors in diagnostics.yaml.
I have my own local yaml (cloned github and changed to my likings) and can live with it.
Would be nice if you would split up the config further in the future, so users can decide which file to include.
Here is an example on the GitHub - Skons/SOAS: ESP32 Alarm clock with Home Assistant integration repo:
packages:
  remote_package_files:
    url: https://github.com/skons/soas
    files: [alarm-clock-soas.yaml, alarm-clock-arduino.yaml, ...]
thx
My apologies for not actually testing that YAML first. The diagnostics.yaml has the default names for the IDs, but we overwrite a couple of the values when we include the file in the base yaml. Below are the correct id’s for all of the diagnostic components.
  boot_id: boot_button
  status_id: bed_presence_status
  factory_reset_id: factory_reset_button
  restart_id: btn_restart
  wifi_db_id: wifi_signal_db
  wifi_percent_id: wifi_signal_percent
  uptime_id: bed_presence_uptime
So it should actually be…
    - id: !remove bed_presence_uptime
This allows more fine grain control and can be done for all components within the diagnostics.yaml, but I like the idea of including individual files to allow for the option of removing all components within a file quickly. It’s something we’ll definitely consider for future releases.
thx for your answer.
I’ll tried it, some worked but the folowing doe not:
Anyways, when you like the idea about split config into files, i think we dont have go the !remove route further.
After 10 days of using the sensor I have to say it’s working very good without an false positive or negative.
I am impressed that the implementation with the timer in the hardware is working so good, without calibration.
Just wanted to say thanks for this project.
Before committing to a purchase, the sensor with mounting kit for a queen bed with box spring, is between the mattress and the box spring?
Thanks!
Hi Stephen,
No Black Friday discounts this year?
Is this still working for you? I have a queen tempur-pedic with Ergo base and I am thinking I might get this. Thanks
Correct, it will rest between the mattress and box spring.
Thanks for checking. We will be doing something for the holiday season, but it will be a bit smaller this year since inventory has been tight. We’ll be posting details in the next few days. Thanks for the support and patience while we work to keep everything in stock!
any plans for updated firmware supporting the recent esphome 25.11 update?
At least for me no problems whatsoever with the recent esphome 25.11 update using these bed presence sensors for two queen sized beds:
Good to know, but I am leaving mine with the production firmware, not with a manually controlled esp home version.
Is there a feature from the 2025.11 release that you’re specifically looking for?
Unless something in the firmware is no longer supported, or there is a new feature we’d like to take advantage of, the production firmware doesn’t get recompiled just to be on the latest release.
Personally I am primarily interested in the wifi and bt proxy enhancements, but there appears to be a lot of improvements to resource efficiency and usage, among many other things.
Oops, I should have read the release notes before my last comment. That’s a pretty significant release, and WiFi performance alone might make it worth it. We’ll do some testing and see if it makes sense to do a release on 2025.11.0.
I recently got an adjustable bed. Will this sensor work on it? Are there any suggestions on placement?
Our holiday sale is almost here! From November 28 to December 12 everything in the store will be 10% off, and orders over $100 will get free U.S. economy shipping. Inventory has been tight the last couple of months so this will be a smaller sale than last year, but everything will be included. Thanks again for all the support. I really appreciate it!
Thanks for the heads up. Someone pointed me to this thread earlier today, so perfect timing.
Will the sale start at a specific time? 12am ET/9pm PT?
Midnight mountain time, so just a little over 4 more hours!
I bought one of these a couple of months ago and it was a treat to set up in Home Assistant, worked instantly and easily; just what I was looking for. Love it.
But, a few days ago, I decided to move it from under my mattress where it was working fine, to between the mattress and the foam pad I have on top of the mattress, thinking I could have a wider range of response and greater accuracy and speed of response.
Unfortunately, I must have messed something up when I re-calibrated it, because it just doesn’t work at all now. I have rebooted it multiple times, unplugged it, checked the sensor connection, etc. It shows up in HA, but is not talking to it.
Can you point me in the right direction? Do I need to pull it out and hook it up to the computer and reflash it or something?
