Hi all,
I followed the instructions from this thread.
https://www.reddit.com/r/Esphome/comments/11p24vk/bed_occupancy_detection_using_pressure_strips/
It seems to work fine when the sensor is outside the bed, but when I put it under the mattress only one side works. I thought that possibly a wire that came loose when I put the mattress on top, but if I lift up the mattress and push it down with my finger it works fine. Does anyone have any ideas why this might work perfectly on one side, but not work at all on the other side.
Here is the esphome code
substitutions:
friendly_name: Master Bedroom Bed Pressure Sensor
esphome:
friendly_name: ${friendly_name}
min_version: 2024.6.0
name_add_mac_suffix: false
project:
version: dev
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "${name}"
password: "KK5Mom3*sgi$SchDVL"
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
authorizer: none
# To have a "next url" for improv serial
web_server:
switch:
- platform: restart
name: Restart ${friendly_name}
- platform: adc
pin: GPIO36
name: "Bed Pressure Brian"
update_interval: 1s
entity_category: "diagnostic"
attenuation: auto
- platform: adc
pin: GPIO39
name: "Bed Pressure Britni"
update_interval: 1s
attenuation: auto
number:
name: "Brian Voltage Threshold"
optimistic: true
min_value: .2
max_value: 3.3
step: .02
restore_value: True
entity_category: "config"
on_value:
- lambda: |-
id(bin_brian).set_upper_threshold(x);
id(bin_brian).set_lower_threshold(x);
name: "Britni Voltage Threshold"
optimistic: true
min_value: .2
max_value: 3.3
step: .02
restore_value: True
on_value:
- lambda: |-
id(bin_britni).set_upper_threshold(x);
id(bin_britni).set_lower_threshold(x);
binary_sensor:
- platform: analog_threshold
device_class: "occupancy"
name: "Bed Brian Occupancy"
sensor_id: pressure_brian
threshold: 0.2
filters:
- invert:
name: "Bed Britni Occupancy"
sensor_id: pressure_britni
threshold: 0.2
filters:
- invert:
