Bedtime sensor
Hi, I was wondering if I could have some help with an automation that will take sensor data and subtract it from a value.
My idea is to have a time input, for when I want to wake up (ex: 6:00AM) then have another time input for how long I want to sleep (ex: 7hr). Then send a notification to my phone for when I should go to sleep to meet the criteria of 7hrs and wake up at 6
Create an Input Datetime to store the wake up time.
Create an Input Number to store the sleep duration (in hours).
Create a Template Sensor that subtracts the value of the Input Number from the Input Datetime and report it as a time (and the current date). Set its device_class to timestamp so it can be used in a Time Trigger.
Create an automation with a Time Trigger that references the Template Sensor. The automation’s action is a notification to your phone.
EDIT
Example of the Template Sensor:
template:
  - sensor:
      - name: Notification Time
        device_class: timestamp
        state: >
         {{ (today_at(states('input_datetime.wakeup_time'))
           - timedelta(hours = states('input_number.sleep_duration') | int(0))).isoformat() }}
Example of the automation:
alias: Sleep Notification
  - platform: time
    at: sensor.notification_time
condition: []
  - service: notify.your_phone
      message: Go to sleep now.
123Taras was faster :slight_smile:
To add something of value:
I use a similar concept that creates a sensor that tells me in how many hours my Alarm is going off.
Maybe its helpful.
Please see below:
- platform: template # Show in Humanreadable language how much time until the alarm goes off
    sensors:
      nextalarm:
        friendly_name: "Next Alarm"
        value_template: >-
          {% if is_state("input_boolean.alarm", "off") -%}
            {% set time= 0 -%}
          {% elif as_timestamp( now().replace(hour=(states.input_datetime.alarm.attributes.hour)).replace(minute=(states.input_datetime.alarm.attributes.minute)).replace(second=0)) - as_timestamp(states('sensor.date_time').replace(',', '')) < 0
          and
          is_state("input_boolean.alarm", "on") -%}
            {% set time = as_timestamp( now().replace(hour=(states.input_datetime.alarm.attributes.hour)).replace(minute=(states.input_datetime.alarm.attributes.minute)).replace(second=0)) + 86400 - as_timestamp(states('sensor.date_time').replace(',', ''))%}
          {% elif as_timestamp( now().replace(hour=(states.input_datetime.alarm.attributes.hour)).replace(minute=(states.input_datetime.alarm.attributes.minute)).replace(second=0)) - as_timestamp(states('sensor.date_time').replace(',', '')) > 0
          and
            {% set time = as_timestamp( now().replace(hour=(states.input_datetime.alarm.attributes.hour)).replace(minute=(states.input_datetime.alarm.attributes.minute)).replace(second=0)) - as_timestamp(states('sensor.date_time').replace(',', ''))%}
          {%- endif %}
          {% set minutes = ((time % 3600) / 60) | int %}
          {% set hours = ((time % 86400) / 3600) | int %}
          {% set days = (time / 86400) | int %}
          {%- if time == "0" -%}
          {%- elif time < 60 -%}
             <1m
          {%- else -%}
            {%- if days > 0 -%}
              {%- if days == 1 -%}
                1d
              {%- else -%}
                {{ days }}d
              {%- endif -%}
            {%- endif -%}
            {%- if hours > 0 -%}
              {%- if days > 0 -%}
              {%- endif -%}
              {%- if hours == 1 -%}
                1h
              {%- else -%}
                {{ hours }}h
              {%- endif -%}
            {%- endif -%}
            {%- if minutes > 0 -%}
              {%- if days > 0 or hours > 0 -%}
              {%- endif -%}
              {%- if minutes == 1 -%}
                1m
              {%- else -%}
                {{ minutes }}m
              {%- endif -%}
            {%- endif -%}
          {%- endif -%}
What is the format to put sensor.notification_time into a card but just with the time, not date?
Use this version that includes an attribute named sleep_time.
template:
  - sensor:
        state: >
        attributes:
          sleep_time: >
              - timedelta(hours = states('input_number.sleep_duration') | int(0))).strftime('%-H:%M') }}
In the Entity card, set the Attribute field to sleep_time.
