When adding a template I’m getting the following error.
Failed to reload configuration
Cannot quick reload all YAML configurations because the configuration is not valid: Error loading /config/configuration.yaml: while parsing a block mapping in “/config/configuration.yaml”, line 3, column 1 expected , but found ‘-’ in “/config/configuration.yaml”, line 23, column 1
YAML below - IP removed from post
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
#Themes
frontend:
script: !include scripts.yaml
scene: !include scenes.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- 0.0.0.0/24
#reverse
covers:
cover.wifi_curtain_motor_curtain_reversed:
friendly_name: wifi_curtain_motor_curtain_reversed
position_template: "{{ 100 - state_attr('cover.wifi_curtain_motor_curtain',
'current_position') | int(100) }}"
open_cover:
service: cover.close_cover
data: {}
entity_id: cover.wifi_curtain_motor_curtain
close_cover:
service: cover.open_cover
data: {}
stop_cover:
service: cover.stop_cover
data: {}
set_cover_position:
service: cover.set_cover_position
position: "{{100-position}}"
icon_template: |-
{% if is_state('cover.wifi_curtain_motor_curtain', 'closed') %}
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
Any help would be greatly appreciated.
Thanks.
