Beginner: Create a Sensor in ESPhome
Hi all,
I’m not very good with this, so I need basic help :frowning: I am very happy I was able to upload a firmware to my ESP32 and feel like a hero already :wink:
I want to test this ultrasonic sensor that people are talking about here:
This is mainly a PoC and I don’t need anything reliable at the moment.
But the first question is how I can get this working at all. I have it all wired up, flashed the firmware on the ESP etc., but I don’t get any sensory input.
My config looks like this:
esphome:
  friendly_name: ultraschall
esp32:
  board: esp32dev
  framework:
    type: arduino
  - platform: ultrasonic
    trigger_pin: GPIO2
    echo_pin: GPIO4
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "el1a4m1ePshETDxxxxxxxA7NKo/wAXECnZZwJQ="
ota:
  - platform: esphome
    password: "1be87d0e2cxxxxxxx2b5e0b669b2"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Ultraschall Fallback Hotspot"
    password: "aoeiaoeiaoeiaoeiaoeiaoei"
captive_portal:
And the flashing worked, but then looked like this:
I tried drawing a Fritzing, but there is no esp32 board with my very ordinary pin out? I tried taking some photos:
Tried to get a better picture of the breadboard:
It does show in HA, but no status of the sensor:
Any idea what I might have done wrong? :frowning:
HI
I take it you have tried pointing the sensor at something within 2m rather than just having it pointing up at the ceiling.
Advanced options:
  • timeout (Optional, float): The number of meters for the timeout. Most sensors can only sense up to 2 meters. Defaults to 2 meters.
Your log says it’s a distance timeout.
Your answer made my heart jump a bit as I thought that would have been a very stupid mistake, but I held my hand in front of it for two minutes and also put an object in front of it with no change:
Good. Now double check your wiring. Breadboards are prone to bad connections.
I moved every cable by one or two “boxes”.
Do you think I should wire it directly? I’m a bit nervous … I burnt the last ESP a week ago when I had a short circuit(?) :smiley:
It looks to me that you don’t actually have a connection going on the breadboard?
And yeah, try using female->female Dupont wires and make direct connection instead.
Yes those 4 wires aren’t connected to anything on the breadboard
I do have connections from the ESP to the breadboard, I highlighted them a bit:
oh no, it is not connected from left to right?!
haha, ok:
They need to be in the same row. Try putting the ones in row 4 up to row 2.
Nice! Glad you got it working. Btw. You shouldn’t be scared of making a direct connection, just check it carefully before powering up.
According to the pictures, you do not have connected wires on the non-soldering field
 trigger_pin: GPIO2
 echo_pin: GPIO4
with board esp
I think that was already established several posts ago and the issue has been solved :wink:
