Hello from this instruction page:
I want to transfer this command to my HA:
Entity_id : media_player.kitchen
media_content_id : ' wie ist es '
spät media_content_type : custom
Unfortunately, I don’t know where to paste the code to make the command callable.
Can somebody help me with it?
Greetings Werner
Gruß Werner
pedolsky
(Pedolsky)
October 7, 2021, 4:01pm
2
You can use it in the action part of an automation or in scripts or as a button action.
Hi there,
Thanks for the answer.
Just tried this like this (automation):
alias: Klingeln Test2
description: ''
- platform: state
entity_id: binary_sensor.ewelink_ds01_ad45ff22_ias_zone
to: 'off'
condition: []
entity_id: media_player.evas_echo_flex
media_content_id: 'what time is it'
media_content_type: custom
Unfortunately there comes an error message.
Is there a bug in the code?
That was nonsense:
And you can address multiple echoes there.
Example:
description: ‘’
- platform: state
to: ‘off’
condition: []
entity_id: media_player.echo_dot_bad
media_content_id: ‘what time is it’
Greetings Werner
pedolsky
(Pedolsky)
October 7, 2021, 5:19pm
5
The automation action first needs a service call.
- service: notify.alexa_media_echo_dotchen
message: Die Katzentoilette wurde benutzt.<break time="500ms"/>Bitte reinige sie.
type: tts
method: speak
pedolsky
(Pedolsky)
October 7, 2021, 5:22pm
6
In a button:
type: custom:button-card
tap_action:
action: call-service
service: media_player.play_media
service_data:
media_content_id: wieviel Uhr ist es
entity_id: media_player.echo_dotchen
Hi there,
Do I see it correctly, with this command Alexa speaks the text specified in the command ?:
pedolsky:
type: tts
method: speak
and with this command I give Alexa a voice command:
Is that so?
I want to be able to give an indirect voice command to Alexa via automation. Command could be “Alexa, turn on the radio”.
How can I use my example to do this?
Thanks very much.
Greetings Werner
pedolsky
(Pedolsky)
October 8, 2021, 9:14am
8
Yes.
The service call notify.alexa_media
is a simple message (Sprachnachricht ) as if you would receive a message on the answering machine. It’s one-way.
The service media_player.play_media
forces an action to be performed by Alexa.
In an automation it looks like this:
- service: media_player.play_media
media_content_id: spiele Antenne Bayern
(There are alternative ways but in my opinion this is the easiest one)
And much much more here: https://github.com/custom-components/alexa_media_player/wiki#sequence-commands-versions–100
Hi there,
unfortunately it doesn’t work for me.
Have the following automation create. The text is there as a routine, it also works as a voice command. However, the automation does not trigger the routine.
The test with “Spiele Antenne Bayern” did not work either.
alias: Klingeln an Alexa leiten
description: ''
- platform: state
to: 'off'
condition: []
message: Es klingelt
mode: single
What could be the reason?
Greetings Werner
pedolsky
(Pedolsky)
October 8, 2021, 1:47pm
10
The service notify.alexa_media
is not always reliable. Use my example above:
type: tts
method: speak
would be:
- service: notify.alexa_media_evas_echo_flex
type: tts
method: speak
Herbert01
(Werner)
October 8, 2021, 1:57pm
11
OK. Thanks.
would then use media_player.play_media.
Therefore, Antenne Bayern is played with the following automation:
description: ''
- platform: state
to: 'off'
condition: []
media_content_id: spiele antenne bayern
But if I enter the command of a routine there, it does not work:
description: ''
- platform: state
to: 'off'
condition: []
media_content_id: Es klingelt
Greetings Werner
Herbert01
(Werner)
October 8, 2021, 2:19pm
12
Whew, got it done.
Thats how it works:
description: ''
- platform: state
to: 'off'
condition: []
media_content_type: routine
Thanks very much. Greetings Werner
Herbert01
(Werner)
October 8, 2021, 2:38pm
13
I hope I can disturb you again. Just noticed that I can only output routines on one device. So I would like to use the following automation:
This works well so far.
Problem: I don’t know how to set the output on multiple devices.
I would still like to
and
media_player.evas_echo_dot_bad
Add.
Greetings Werner
This is how it works with one device:
alias: Klingeln Ring the door bells
- platform: state
entity_id: binary_sensor.down_ring_ding
to: 'on'
entity_id: media_player.bose_smart_soundbar_300
media_content_type: sound
media_content_id: amzn_sfx_doorbell_chime_01
- media_player.bose_smart_soundbar_300
type: tts
message: Achtung.
mode: single
pedolsky
(Pedolsky)
October 8, 2021, 5:02pm
14
No problem.
entity_id:
- media_player.1
- media_player.2
media_content_type: …
media_content_id: …
- media_player.1
- media_player.echo_2
message: …
type: tts
Herbert01
(Werner)
October 8, 2021, 5:09pm
15
Hi there,
now everything works great. Exactly as requested.
Thank you very, very, very much.
And a nice weekend.
Greetings Werner
pedolsky
(Pedolsky)
October 8, 2021, 5:50pm
16
Glad to hear. Nice weekend, too!
