Beginner set-up / Home Assistant Green for Hue and Zigbee / Any further hardware required?
Hello Community,
I moved into our new home and want to include some automatization to it and learned about Home Assistant which sounds great. Before I buy my beginner set-up, it would be great if you help me out whether the Home Assistant Green device will be sufficient for my needs.
I would like to buy the Home Assistant Green device. My Hue set-up should not be an issue, I assume. Is my understanding correct that the Home Assistant Green device will replace my Hue Bridge?
Furthermore, I would like to use a Sonoff ZBMINIL2 Extreme Switch. Could you let me know whether I can use it with Home Assistant Green? Or do I need some further hardware (HomeAssistant Skyconnect)?
Many thanks and best regards,
Patrick
