Beginners question about line continuation in HA yaml
This code in an automation yaml snippet runs fine:
alias: test automation 2
description: Test automation for learning trigger variables even better
  - entity_id:
      - sensor.random_sensor
    above: 5
    trigger: numeric_state
    below: 10
conditions: []
actions:
  - action: persistent_notification.create
    metadata: {}
      title: Value between thresholds
      notification_id: value_between
      message: >
        {{ trigger.entity_id }} is above {{ trigger.above }} and below {{ trigger.below }}( {{ states("sensor.random_sensor") }} )
mode: single
but when removing the > so that the message is on one line in the editor I get a red line on the left in the editor and the following error when pressing the Save button: Error in parsing YAML: bad indentation of a mapping entry (line: 16, column: 40)
How come?
If you want to remove the > then you need:
      message: "{{ trigger.entity_id }} is above {{ trigger.above }} and below {{ trigger.below }}( {{ states('sensor.random_sensor') }} )"
So swapped the " for single in the syntax and a " as outer
Thanks for the speedy reply!
Your suggestion gave and error message when saving:
Message malformed: template value should be a string for dictionary value @ data[‘actions’][0][‘data’]
But the following worked
message: ´{{ trigger.entity_id }} isabove {{ trigger.above }} and below {{ trigger.below }}( {{ states("sensor.random_sensor") }} )´
The version with the “>” is more readable, but I was curious why the other would not parse.
In python and in this case in yaml whitespace infront of the first command really matters. It is a weird design concept of the language. Some love it, some hate it. But you absolutely need the right amount of spaces.
You didn’t use the syntax I posted.
Just copy paste it and it will work
