I just spent a few hours with HA so please be kind
I am trying to build a view which includes some auto created groups from the default view like the climate group for example.
It seems that I have to rebuild the sensors from my thermostats if I would like to group them by myself and use them in a custom view?
If there is anyone out with homematic thermostats who could shade some light on me, this would be great!
Ok Sorry, I have a custom view and I would like to get the climate card as a part of my new composed view.
trying to add “climate_view” to the entities of my default_view is not working:
“no” makes this group a panel (card), “yes” makes it a separate view.
It’s hard to break Home Assistant by experimenting with the configuration.yaml file, so try changing things and see what happens.
EXCEPT- Don’t restart Home Assistant without verifying the configuration.yaml is OK. (Configuration, General, Check-config).
“climate_view” was just a name I gave to my group. It’s not what you should add. If you look at your entities you must see the name of the group you would like to add. It should start with “group.”
