Beginning: Hass SSH-access or Integration iRobot
Hi all,
I am (regarding HAss) a real newbie and trying to get used to it.
I installed it (nearly without any issues) as appliance running on VMware ESXi.
The initial setup did run and now I was trying to add my vacuum (Roomba S9+) and cleaner (Braava Jet m6) to the HAss installation.
The automated detection did not work as my HAss is located in a different network as the roboters.
Ok, the GUI tells me to get the password and BLID based on here or here.
I tried to follow them but did not succeed.
As I first step I realized I have to work on the console (which usually is not an issue for me). Unfortunately I do not know the root-password for the HAss appliance so I installed the SSH-server add-on. When opening I am at least able to perform some step as root (in a busybox shell environment).
But none of the linked instructions have been available. Neither the npm command nor python nor docker is available in this shell.
~ $ npm install -g dorita980
bash: npm: command not found
~ $ docker run -it node sh -c "npm install -g dorita980 && get-roomba-password <robotIP>"
bash: docker: command not found
~ $ python ./roomba.py
bash: python: command not found
~ $ python3 ./roomba.py
bash: python3: command not found
~ $ find / -name "*room*"
I assume the add-on only offers me a limited shell (probably itself inside a docker?).
So how do I get to the correct shell of the HAss appliance? I did not find any information about the root-password or enabling ssh access.
Thanks!
/KNEBB
