I’m hoping to get some ideas on how to investigate why my Bluetooth adapter no longer works after a few days.
I’m running Debian 11,
cat /etc/debian_version
11.5
on an older i7 desktop (16g core) to run many things including HA in Docker. I’ve tried 2 different Bluetooth chipsets, 5.0 and 5.1 versions.
It starts with this in system logs:
Bluetooth: hci0: command 0x2042 tx timeout
Bluetooth: hci0: failed to disable LE scan: status 0x1f
HA reports this:
2022-11-19 11:38:04.036 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 372, in _async_scanner_watchdog
await self._async_reset_adapter()
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 389, in _async_reset_adapter
result = await async_reset_adapter(self.adapter)
File "/usr/src/homeassistant/homeassistant/components/bluetooth/util.py", line 112, in async_reset_adapter
return await recover_adapter(adapter_id)
File "/usr/local/lib/python3.10/site-packages/bluetooth_auto_recovery/recover.py", line 251, in recover_adapter
async with MGMTBluetoothCtl(hci, MGMT_PROTOCOL_TIMEOUT) as adapter:
File "/usr/local/lib/python3.10/site-packages/bluetooth_auto_recovery/recover.py", line 116, in __aenter__
await self._setup()
File "/usr/local/lib/python3.10/site-packages/bluetooth_auto_recovery/recover.py", line 137, in _setup
self.sock = btmgmt_socket.open()
File "/usr/local/lib/python3.10/site-packages/btsocket/btmgmt_socket.py", line 58, in open
raise BluetoothSocketError("Unable to open PF_BLUETOOTH socket")
btsocket.btmgmt_socket.BluetoothSocketError: Unable to open PF_BLUETOOTH socket
I can “unplug and then plug it back in” and it seems to recover briefly. But ultimately, I have to “turn off then turn back on” the machine to get it to work for a few more days.
Bluetooth continues to be a fragile and confusing interface on Linux. I think I’ve been down many of the rabbit holes you have been. Based on my experience, I would carefully look for some software running (or something you are doing by accident) that is accessing the Bluetooth adapter in addition to Home Assistant. Regardless of what will be offered, I just do not think it is reliable let more than one application access a give bluetooth adapter. Yes, some things do work successfully, however some code does not. Especially when doing BLE advertising scanning in my experience. Which is kind of core to a lot of the bluetooth HA stuff that is currently being done.
I went down the firmware update path, made no difference.
Bluetooth 5.x vs. 4.x adapters, 5 seems less stable to me due to requiring the newer BlueZ and D-Bus to work as well as the older legacy APIs. Not that the old API’s seemed that stable prior to the new stuff.
BlueZ versions, another whole ‘hole’…
IMHO doing nothing Bluetooth on your HA server and abstracting all bluetooth communication using proxy devices via remote ESPHome or MQTT for C2 seems to be the best path.
Hope you find an answer! Good hunting! It is a PIA…
Did you find something?
My TP-Link UB500 (not the best choice) stopped working. I presume itś related to at least one of the updates. It could be the Debian or the HA upgrade of last week.
I’m running HA supervised on a Debian VM in Proxmox.
Just sayin’ my Home Assistant server with NO bluetooth direct stuff runs one year plus without touching. My remote raspberry pi 3B also runs one year plus, no touch, delivering BLE sensor broadcasts to HA server via MQTT. “Bob’s your uncle”, pick ur battles. …good hunting!
Yes, I’m getting to that point. I’ve been meaning to investigate having my RPIs handle BLE and send to HA via MQTT. I’ve had success with other sensors (e.g. rtl_433) using MQTT – just works.
Hope you find a solid solution for your config. As I said, I am very happy with my BLE sensor, especially the temperature, humidity, CO2 and AQI devices. I started early, so used a RPI for the collector, but it really looks the ESP32 based devices are the way to go now. Good hunting!
Will close this thread out as I moved off the HA Bluetooth Integration and switched to an RPI3+ and MQTT (paho) client to read and publish advertisements from my BLE sensors. Thanks for the tip!
I was able to create a simple Python MQTT client leveraging the great work of the contributors of the sensor.goveetemp_bt_hci and https://github.com/TheCellule/python-bleson projects. The gist is from bleson import get_provider and from govee_advertisement import GoveeAdvertisement.
I know this was solved, but this works for me on debian w/usb realtek usb adapter, little overcomplicated, but keeps bt responding, add a crontab job to run it every few minutes.
#!/bin/bash
# Set lock file path
LOCK_FILE=~/usbresetBT/resetusb.lock
LOG_FILE=~/usbresetBT/resetusb.log
# Check if log file exists and create if it doesn't
if [ ! -e "$LOG_FILE" ]; then
touch "$LOG_FILE"
fi
# Check if lock file exists
if [ -e "$LOCK_FILE" ]; then
# Check if lock file is older than 20 minutes
if find "$LOCK_FILE" -mmin +20 | grep -q .; then
echo "$(date +"%b %d %T") Lock file is older than 20 minutes, removing lock file" >> ~/usbresetBT/resetusb.log
rm "$LOCK_FILE"
else
echo "$(date +"%b %d %T") Script is already running, exiting" >> ~/usbresetBT/resetusb.log
exit 1
fi
fi
# Create lock file
touch "$LOCK_FILE"
# Set maximum log file size (in bytes)
MAX_LOG_SIZE=20000
# Get the output of bluetoothctl devices command
devices_output=$(bluetoothctl devices)
# Get the number of devices found
num_devices=$(echo "$devices_output" | grep -c "Device")
# Check if the number of devices found is less than 3 (change to your preference).
if [ "$num_devices" -lt 3 ]; then
echo "$(date +"%b %d %T") TOO FEW DEVICES FOUND: Restarting BT SERVICE!" >> ~/usbresetBT/resetusb.log
echo "$(date +"%b %d %T") Devices information before restarting:" >> ~/usbresetBT/resetusb.log
echo "$devices_output" >> ~/usbresetBT/resetusb.log
echo -n "1-1.3" > sudo /sys/bus/usb/drivers/btusb/unbind
sleep 1
echo -n "1-1.3" > sudo /sys/bus/usb/drivers/btusb/bind
sleep 1
sudo systemctl restart bluetooth
if [ $? -eq 0 ]; then
echo "$(date +"%b %d %T") Bluetooth service restarted successfully" >> ~/usbresetBT/resetusb.log
sleep 50
echo "$(date +"%b %d %T") Devices information after restarting:" >> ~/usbresetBT/resetusb.log
echo "$(bluetoothctl devices)" >> ~/usbresetBT/resetusb.log
else
echo "$(date +"%b %d %T") Failed to restart Bluetooth service" >> ~/usbresetBT/resetusb.log
fi
else
echo "$(date +"%b %d %T") Devices Responding Normally" #>> ~/usbresetBT/resetusb.log
fi
# Check log file size and rotate if necessary
file_size=$(stat -c%s ~/usbresetBT/resetusb.log)
if [ $file_size -ge $MAX_LOG_SIZE ]; then
mv ~/usbresetBT/resetusb.log ~/usbresetBT/resetusb.log.old
fi
rm "$LOCK_FILE"
output (removed full mac’s):
Can remove the comment from echo “$(date +”%b %d %T") Devices Responding Normally" #>> ~/usbresetBT/resetusb.log if you want to log when devices are responding normally.
Apr 04 19:51:01 TOO FEW DEVICES FOUND: Restarting BT SERVICE!
Apr 04 19:51:01 Devices information before restarting:
Apr 04 19:51:03 Bluetooth service restarted successfully
Apr 04 19:51:53 Devices information after restarting:
Device 7D:B5:C9
Device CD:E9:44
Device A4:C1:38
Device A4:C1:38
Device D9:B9:C4
Device F6:54:F5
Device A4:C1:38
Device 6E:F7:F1
Device A4:C1:38
Device A4:C1:38
Device CB:C3:CA
Device 2F:DE:0F
Device 4A:DA:80
Device C4:2E:25
Device 0B:78:4B
Device A4:C1:38
Device 54:48:E6
Device 7D:33:BC
Device 38:56:3D
Device C8:8C:1C
Device 11:70:E1
This thread seems dead, but if I google “hci0 unable to disable scanning” this post comes out on top.
I thought I’d share my little “fix”.
I saw in the dmesg log, that hci0 was unable to disable a scan that I can see in the HA logs was initiated here. This causes the module to crash and resubmit as hci1. This ofcourse causes the module to become unreachable to Home Assistant.
My fix was asking an AI, in this instance Claude, to write me a udev rule that forces the bluetooth module to always resubmit as hci0.
Now my logs show, that the module fails to resubmit to hci1 and starts back up as hci0.
This does not actually fix the crashing, but instead of having to reboot the system, I just get a little chop on my measurements every 1-2 days, when the module restarts.
But I’ll keep looking for a “real fix” so theres no crashes at all.
From what I’ve learned, it is not only my type of module (rtl_bt/rtl8852bu), and it only seems to be occuring on Linux systems running HA. Maybe I’ll look into how the module is exsposed to my HA through Docker, or try and figure out how to make the HA the only thing to be able to access the module.
Surely the proper “fix” would be to get a supported adapter and treat the cause, rather than the symptom.
There’s a warning regarding Realtek Adapters on that page. The closest model to yours (RTL8821CU) is listed as being unsupported due to Frequent connection failures and drop outs.
If I were in your shoes, I’d call it a day and get a CSR bluetooth module.
Thanks for this. You are probably correct - this module will never function correctly with the Home Assistant bluetooth integration. I’m not keen on buy a super old BT4.0 (CSR8510A10) adapter. I had a couple ESP32 laying around, so I made an ESPHome bluetooth proxy. This shows up as a bluetooth device in the bluetooth integration. Then i disabled the defective bluetooth on my Ubuntu machine altogether by sudo systemctl disable bluetooth. It was a bit tricky setting up with a Docker setup. But it works now. Will have to wait for stability.
