Behringer Digital Mixer integration
I’ve just created a new integration that allows you to connect a Behringer Digital Mixer to Home Assistant.
Mixers Supported
  • X32
  • XR12
  • XR16
  • XR18
For each mixer configured by this integration entities for the following are provided.:
For each Channel, Bus, DCA, Matrix, and Main Faders
  • Name (Read only)
  • Mute (SWITCH) (Read/Write)
  • Fader (NUMBER) (Read/Write)
  • Fader Value - dB (SENSOR) (Read only)
In addition to these ‘fader’ related variables, also provided is
  • Current scene/snapshot number/index (Read/Write)
Data Updates
The data for the mixer is updated in real time, so each time a button is pressed or fader is moved on the mixer, this is updated in Home Assistant immediately.
Integration is available here - GitHub - wrodie/ha_behringer_mixer: Home Assistant integration for Behringer Digital Mixers eg (X32)
and can be installed with HACS
Entities can be viewed as switches/sensors/numbers in HA as well as being used in automation.
I’ve also created a Lovelace card GitHub - wrodie/mixer-card: Mixer card for Home Assistant that allows you to manage the channels as faders.
I have installed and it works really well so far.
THANK YOU!!!
I’ll have to give this a try. I use a dedicated monitor for my x18, but this looks like a fun project.
Thank you ! Ho cna I support you ? Where is BuyMeACoffe link :wink:
