Belgium's/Flanders capacity consumption
Belgium’s/Flanders capacity consumption
I created a blueprint to calculate capacity consumption in Flanders. I used some automations since late 2022. Since April 2023, I have had a digital meter and all calculations are reasonably correct (accurate to ±50 Wh).
As some colleagues have requested the automation, I made a blueprint of it. And hopefully I can help more persons with it.
What’s present:
  • Monthly tracking of maximum consumption for the month (choice to start from 0 or 2.5kWh)
  • Total last year average (keep in mind minimum of 2.5kWh)
  • Maximum peak of the month (reset monthly)
  • Current actual consumption converted to an hour
  • Warning and alarm boolean in case of excessive consumption
The blueprint uses a lot of helpers to keep track of the data. Not all helpers are mandatory.
Attention, everything is in kWh !!!
To start, a utility meter must be created where the current consumption of the digital meter must be linked and set to reset every 15min.
The following helpers (input_numbers) are mandatory:
  • Maximum : maximum consumption of the current month (resets to 0 every month)
  • Each month : maximum consumption of each month
The following helpers (input_numbers) are optional:
  • Actual : current quarter consumption converted to hourly value
  • Average : average consumption of the last 12 months
The following helpers (input_booleans) are optional:
  • Warning : if the quarter consumption reaches the warning threshold, the boolean comes high
  • Alarm : if the quarter consumption reaches the alarm threshold, the boolean comes high
Blueprint or GitHub
blueprint:
  name: Belgium's/Flanders capacity consumption
  description: Calculates the maximum capacity consumption per month and the average of the last year
  domain: automation
  input:
    utility_sensor:
      name: Utility meter quarterly consumption *
      description: Create a utility meter where the actual consumption of electricity is reset every 15 minutes
      selector:
        entity:
          domain: sensor
          device_class: energy
    minimum:
      name: Minimum value quarter consumption *
      description: Minimum defined quarter consumption
      default: 2.5
      selector:
        number:
          min: 0
          max: 10
          step: 0.1
          unit_of_measurement: kWh
    reset_minimum:
      name: Reset with minimum defined quarter consumption *
      description: Reset monthly data with the minimum defined quarter consumption (off=0 | on=quarter consumption)
      default: true
      selector:
        boolean:
    maximum_helper:
      description: Numerical helper for maximum consumption for the actual month (kWh)
      selector:
        entity:
          domain: input_number
    actual_helper:
      name: Actual (optional)
      description: Numerical helper for actual consumption for the current quarter (kWh)
      default: []
      selector:
        entity:
    average_helper:
      name: Average (optional)
      description: Numerical helper for average consumption for the last year (kWh)
      default: []
      selector:
        entity:
    month_01_helper:
      description: Numerical helper for maximum consumption for the month of January (kWh)
      selector:
        entity:
    month_02_helper:
      description: Numerical helper for maximum consumption for the month of February (kWh)
      selector:
        entity:
    month_03_helper:
      description: Numerical helper for maximum consumption for the month of March (kWh)
      selector:
        entity:
    month_04_helper:
      description: Numerical helper for maximum consumption for the month of April (kWh)
      selector:
        entity:
    month_05_helper:
      description: Numerical helper for maximum consumption for the month of May (kWh)
      selector:
        entity:
    month_06_helper:
      description: Numerical helper for maximum consumption for the month of June (kWh)
      selector:
        entity:
    month_07_helper:
      description: Numerical helper for maximum consumption for the month of July (kWh)
      selector:
        entity:
    month_08_helper:
      description: Numerical helper for maximum consumption for the month of August (kWh)
      selector:
        entity:
    month_09_helper:
      description: Numerical helper for maximum consumption for the month of September (kWh)
      selector:
        entity:
    month_10_helper:
      description: Numerical helper for maximum consumption for the month of October (kWh)
      selector:
        entity:
    month_11_helper:
      description: Numerical helper for maximum consumption for the month of November (kWh)
      selector:
        entity:
    month_12_helper:
      description: Numerical helper for maximum consumption for the month of December (kWh)
      selector:
        entity:
    warning_value:
      name: Warning value (optional)
      description: Activate warning boolean helper from this value
      default: 2.0
      selector:
        number:
          min: 0
          max: 50
          step: 0.1
    warning_helper:
      name: Warning (optional)
      description: Boolean helper for warning consumption for the current quarter is above the limit (boolean)
      default: []
      selector:
        entity:
          domain: input_boolean
    alarm_value:
      name: Alarm value (optional)
      description: Activate alarm boolean helper from this value
      default: 2.5
      selector:
        number:
          min: 0
          max: 50
          step: 0.1
    alarm_helper:
      name: Alarm (optional)
      description: Boolean helper for alarm consumption for the current quarter is above the limit (boolean)
      default: []
      selector:
        entity:
variables:
  minimum_value: !input minimum
  warning_value: !input warning_value
  alarm_value: !input alarm_value
  utility_sensor: !input utility_sensor
  maximum_helper: !input maximum_helper
  average_helper: !input average_helper
  actual_helper: !input actual_helper
  month_01_helper: !input month_01_helper
  month_02_helper: !input month_02_helper
  month_03_helper: !input month_03_helper
  month_04_helper: !input month_04_helper
  month_05_helper: !input month_05_helper
  month_06_helper: !input month_06_helper
  month_07_helper: !input month_07_helper
  month_08_helper: !input month_08_helper
  month_09_helper: !input month_09_helper
  month_10_helper: !input month_10_helper
  month_11_helper: !input month_11_helper
  month_12_helper: !input month_12_helper
  warning_helper: !input warning_helper
  alarm_helper: !input alarm_helper
  reset_minimum: !input reset_minimum
  reset_minimum_value: "{{ minimum_value if reset_minimum else 0 }}"
  month_01_value: "{{ (states[month_01_helper].state | float(default=0)) if (states[month_01_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_02_value: "{{ (states[month_02_helper].state | float(default=0)) if (states[month_02_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_03_value: "{{ (states[month_03_helper].state | float(default=0)) if (states[month_03_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_04_value: "{{ (states[month_04_helper].state | float(default=0)) if (states[month_04_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_05_value: "{{ (states[month_05_helper].state | float(default=0)) if (states[month_05_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_06_value: "{{ (states[month_06_helper].state | float(default=0)) if (states[month_06_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_07_value: "{{ (states[month_07_helper].state | float(default=0)) if (states[month_07_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_08_value: "{{ (states[month_08_helper].state | float(default=0)) if (states[month_08_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_09_value: "{{ (states[month_09_helper].state | float(default=0)) if (states[month_09_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_10_value: "{{ (states[month_10_helper].state | float(default=0)) if (states[month_10_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_11_value: "{{ (states[month_11_helper].state | float(default=0)) if (states[month_11_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  month_12_value: "{{ (states[month_12_helper].state | float(default=0)) if (states[month_12_helper].state | float(default=0)) > minimum_value else minimum_value }}"
  capacity_hour_utility: "{{ states[utility_sensor].state | float(default=0) * 4 }}"
  capacity_hour_helper: "{{ states[maximum_helper].state | float(default=0) }}"
  capacity_hour_max: "{{ capacity_hour_utility > capacity_hour_helper }}"
  capacity_average: "{{ (month_01_value + month_02_value + month_03_value + month_04_value + month_05_value + month_06_value + month_07_value + month_08_value + month_09_value + month_10_value + month_11_value + month_12_value ) / 12 }}"
  average_enabled: "{{ average_helper | length > 0 }}"
  actual_enabled: "{{ actual_helper | length > 0 }}"
  warning_enabled: "{{ warning_helper | length > 0 }}"
  warning_state: "{{ capacity_hour_utility > warning_value }}"
  alarm_enabled: "{{ alarm_helper | length > 0 }}"
  alarm_state: "{{ capacity_hour_utility > alarm_value }}"
  # Reset maximum en month value (Only reset when the new month is in progress as 1 minute to avoid problems and overlap)
  - platform: time
    at: "00:01:00"
  # Calculate the MAX
  - platform: state
    entity_id: !input utility_sensor
  # Calculate average
  - platform: state
    entity_id: !input maximum_helper
  choose:
    # RESET
    - conditions:
        - condition: trigger
      sequence:
        - if:
            - condition: template
              value_template: "{{ now().day == 1 }}"
          then:
            - choose:
                - conditions:
                      value_template: "{{ now().month == 1 }}"
                  sequence:
                    - service: input_number.set_value
                        value: "{{ reset_minimum_value }}"
                        entity_id: !input month_01_helper
                - conditions:
                      value_template: "{{ now().month == 2 }}"
                  sequence:
                        entity_id: !input month_02_helper
                - conditions:
                      value_template: "{{ now().month == 3 }}"
                  sequence:
                        entity_id: !input month_03_helper
                - conditions:
                      value_template: "{{ now().month == 4 }}"
                  sequence:
                        entity_id: !input month_04_helper
                - conditions:
                      value_template: "{{ now().month == 5 }}"
                  sequence:
                        entity_id: !input month_05_helper
                - conditions:
                      value_template: "{{ now().month == 6 }}"
                  sequence:
                        entity_id: !input month_06_helper
                - conditions:
                      value_template: "{{ now().month == 7 }}"
                  sequence:
                        entity_id: !input month_07_helper
                - conditions:
                      value_template: "{{ now().month == 8 }}"
                  sequence:
                        entity_id: !input month_08_helper
                - conditions:
                      value_template: "{{ now().month == 9 }}"
                  sequence:
                        entity_id: !input month_09_helper
                - conditions:
                      value_template: "{{ now().month == 10 }}"
                  sequence:
                        entity_id: !input month_10_helper
                - conditions:
                      value_template: "{{ now().month == 11 }}"
                  sequence:
                        entity_id: !input month_11_helper
                - conditions:
                      value_template: "{{ now().month == 12 }}"
                  sequence:
                        entity_id: !input month_12_helper
    # UTILITY CHANGE
    - conditions:
      sequence:
        - if:
              value_template: "{{ capacity_hour_max }}"
          then:
            - choose:
                - conditions:
                  sequence:
                        value: "{{ capacity_hour_utility }}"
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
                - conditions:
                  sequence:
        - parallel:
            - if:
                  value_template: "{{ actual_enabled }}"
              then:
                    entity_id: !input actual_helper
            - if:
                  value_template: "{{ warning_enabled }}"
              then:
                - if:
                      value_template: "{{ warning_state }}"
                  then:
                      data: {}
                        entity_id: !input warning_helper
                  else:
                    - service: input_boolean.turn_off
                      data: {}
            - if:
                  value_template: "{{ alarm_enabled }}"
              then:
                - if:
                      value_template: "{{ alarm_state }}"
                  then:
                      data: {}
                        entity_id: !input alarm_helper
                  else:
                      data: {}
    # AVERAGE
    - conditions:
          value_template: "{{ average_enabled }}"
      sequence:
            value: "{{ capacity_average }}"
            entity_id: !input average_helper
mode: parallel
max: 3
Some bugs had slipped into the blueprint, I fixed the following:
  • Maximum helper is now reset to 0 along with every month
  • Reset to minimum value now works correctly instead of always starting from 0 (keep in mind the option)
Re-import the blueprint and these are solved
