Would the Belkin NetCam HD+ a wemo cam be compatible with HA without any bridge?
Can’t find any information on that.
You could generate a URL to access it with FFMPEG using this site:
https://www.ispyconnect.com/man.aspx?n=Belkin+NetCam+HD#
But that’s the best I can offer at the moment.
Must it be FFMPEG to be compatible with HA?
In this case I think it’s the only way to get a stream out of the Belkin. I don’t have any experience with them but if there is a web UI for it, you may be able to check out the image/stream by right clicking on it and seeing if it will open in another tab. If it shows the image/stream in the tab and nothing else (and it’s working), you may be able to use that tab’s URL with one of the generic camera components.
