Beok TGR86-ZB Zigbee Underfloor Heating Thermostat
Having looked on the website, I found Beok Under Floor Heating Thermostat (TGR85-ZB) Zigbee compatibility and ordered the TGR86-AB based on it being reported as working. While I can add the device and it is working as a router based on my zigbee topology, no entities are created.
Below is the device signature and I’ve attached a truncated debug log underneath. I’m not very familiar with this level of detail unfortunately. Do I need to map this to another model to make it work or is something more significant required. I did see a thread for a HACS component for a Wi-Fi version but didn’t think that would be a good starting point.
Donald
  "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
  "endpoints": {
    "1": {
      "profile_id": 260,
      "device_type": "0x0051",
      "in_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xef00"
      "out_clusters": [
"0x000a",
"0x0019"
    "242": {
      "profile_id": 41440,
      "device_type": "0x0061",
      "in_clusters": [],
      "out_clusters": [
"0x0021"
  "manufacturer": "_TZE200_2ekuz3dz",
  "model": "TS0601",
  "class": "zigpy.device.Device"
2022-05-25 18:18:47 DEBUG (MainThread) [zigpy.appdb] [0xb6a9:1:0x0000] Attribute id: 4 value: _TZE200_2ekuz3dz
2022-05-25 18:18:47 DEBUG (MainThread) [zigpy.appdb] [0xb6a9:1:0x0000] Attribute id: 5 value: TS0601
2022-05-25 18:18:47 DEBUG (MainThread) [zigpy.appdb] [0xb6a9:1:0x0000] Attribute id: 1 value: 70
2022-05-25 18:18:47 DEBUG (MainThread) [zigpy.appdb] [0xb6a9:1:0x0000] Attribute id: 65506 value: 54
2022-05-25 18:18:47 DEBUG (MainThread) [zigpy.appdb] [0xb6a9:1:0x0000] Attribute id: 65508 value: 0
2022-05-25 18:18:47 DEBUG (MainThread) [zigpy.appdb] [0xb6a9:1:0x0000] Attribute id: 65503 value: U.!*ie.!*iu.!*i�.!*i�.!*i�.!*i�.!*i�.!*i�.!*i�.!*i
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] [0xB6A9](_TZE200_2ekuz3dz TS0601) restored as 'available', last seen: 0:01:33 ago, consider_unavailable_time: 7200 seconds
2022-05-25 18:18:59 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.SrcRtgInd.Callback(DstAddr=0xB6A9, Relays=[])
2022-05-25 18:18:59 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=57, SecurityUse=<Bool.false: 0>, TimeStamp=525757, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xB6A9](TS0601): started initialization
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:ZDO](TS0601): 'async_initialize' stage succeeded
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0000]: initializing channel: from_cache: True
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0000]: finished channel initialization
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0019]: initializing channel: from_cache: True
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0019]: finished channel initialization
2022-05-25 18:18:59 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Received ZCL frame: b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD'
2022-05-25 18:18:59 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, is_reply=1, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False), tsn=113, command_id=2, *is_reply=True)
2022-05-25 18:18:59 WARNING (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Unknown cluster command 2 b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:18:59 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Received command 0x02 (TSN 113): b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:18:59 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] No explicit handler for cluster command 0x02: b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:18:59 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=60, SecurityUse=<Bool.false: 0>, TimeStamp=538064, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:18:59 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=57, SecurityUse=<Bool.false: 0>, TimeStamp=550588, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0000]: 'async_initialize' stage succeeded
2022-05-25 18:18:59 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0019]: 'async_initialize' stage succeeded
2022-05-25 18:19:00 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=57, SecurityUse=<Bool.false: 0>, TimeStamp=563109, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:19:00 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=63, SecurityUse=<Bool.false: 0>, TimeStamp=575627, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:19:00 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xB6A9](TS0601): power source: Mains
2022-05-25 18:19:00 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xB6A9](TS0601): completed initialization
2022-05-25 18:19:00 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Received ZCL frame: b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD'
2022-05-25 18:19:00 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, is_reply=1, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False), tsn=113, command_id=2, *is_reply=True)
2022-05-25 18:19:00 WARNING (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Unknown cluster command 2 b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:19:00 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Received command 0x02 (TSN 113): b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:19:00 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] No explicit handler for cluster command 0x02: b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:19:00 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xB6A9](TS0601): started initialization
2022-05-25 18:19:00 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:ZDO](TS0601): 'async_initialize' stage succeeded
2022-05-25 18:19:00 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=63, SecurityUse=<Bool.false: 0>, TimeStamp=588150, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:19:01 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0000]: initializing channel: from_cache: False
2022-05-25 18:19:01 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0000]: finished channel initialization
2022-05-25 18:19:01 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0019]: initializing channel: from_cache: False
2022-05-25 18:19:01 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0019]: finished channel initialization
2022-05-25 18:19:01 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=60, SecurityUse=<Bool.false: 0>, TimeStamp=600734, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:19:01 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=60, SecurityUse=<Bool.false: 0>, TimeStamp=613253, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:19:01 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=60, SecurityUse=<Bool.false: 0>, TimeStamp=625777, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:19:01 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.IncomingMsg.Callback(GroupId=0x0000, ClusterId=61184, SrcAddr=0xB6A9, SrcEndpoint=1, DstEndpoint=1, WasBroadcast=<Bool.false: 0>, LQI=60, SecurityUse=<Bool.false: 0>, TimeStamp=638362, TSN=0, Data=b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD', MacSrcAddr=0xB6A9, MsgResultRadius=29)
2022-05-25 18:19:01 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Received ZCL frame: b'\x09\x71\x02\x00\x19\x18\x02\x00\x04\x00\x00\x00\xFD'
2022-05-25 18:19:01 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, is_reply=1, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False), tsn=113, command_id=2, *is_reply=True)
2022-05-25 18:19:01 WARNING (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Unknown cluster command 2 b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:19:01 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] Received command 0x02 (TSN 113): b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:19:01 DEBUG (MainThread) [zigpy.zcl] [0xB6A9:1:0xef00] No explicit handler for cluster command 0x02: b'\x00\x19\x18\x02\x00\x04\x00\x00\x00\xfd'
2022-05-25 18:19:01 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0000]: 'async_initialize' stage succeeded
2022-05-25 18:19:01 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB6A9:1:0x0019]: 'async_initialize' stage succeeded
Replying to my own post, I bought a similar device from Samotech which works.
Comparing their signatures the biggest difference seems to be the quirk.
It is possible to add a quirk via configuration.yaml? I’m not up to editing the source code and having spent the last few hours reading countless pages I haven’t found a way.
Nwk: 0x834e
Device Type: Router
LQI: 81
RSSI: Unknown
Quirk: zhaquirks.tuya.ts0601_electric_heating.MoesBHT
Have you made any progress on the TGR85-ZB? Looking for an underfloor electric heating thermostat system that works good with HA.
No progress sorry. I will probably buy a second device from samotech once they have them back in stock as I know they work. Wall Mounted Zigbee Thermostat for Underfloor Heating – SAMOTECH
How do you find the quality and look and feel of the Samotech device? At less than £40 they looks a bit of a steal, but if they are cheap looking then the WAF will take a bit of a hit!
Here are a couple of pictures of them in situ. I’ve had no complaints about them though of course now that we control it all through home assistant they are pretty much untouched.
They talk about two different versions: TGR86-AB and TGR85-ZB. Neither of these work with zigbee2mqtt?
One question the Samotech works the increment of 0.5 °C. Me with a Moes BHT-002 it only allows me increments of 1°C, and I think they are the same.
Hello, did anyone ever get this working? I just received mine after seeing it as working on the ZHA page, but can’t get any entities in home assistant!
