I reverse-engineered the BLE protocol of the Berbel BFB 6bT remote control and built an ESP32-based emulator that bridges the hood to Home Assistant via MQTT.
Why?
Berbel kitchen hoods (Skyline Frame, Edge, Glassline, etc.) use a proprietary BLE remote with no official smart home integration beyond an iOS-only app. This project gives you full control through Home Assistant.
What it does
The ESP32 emulates the original remote control over BLE and exposes the hood as MQTT entities with auto-discovery:
Lights - Upper light and cooktop light (toggle with state tracking)
Fan - Select entity with 5 speeds (Off, Stufe 1-3, Power)
Position - Raise/lower the hood
Afterrun - Toggle the afterrun timer
Power Off - Button entity
Status - Real-time state from the hood (9-byte bitmask decoded)
BLE Connection - Diagnostic binary sensor
All entities reflect the actual hood state, not optimistic updates. The hood sends status packets that are decoded in real-time.
Key discoveries during reverse engineering
The hood filters by MAC OUI and only accepts Texas Instruments MACs (88:01:F9 or 30:AF:7E). ESP32 MAC must be
spoofed.
Legacy BLE pairing with LTK only (no IRK). Adding IRK breaks pairing.
GATT services must be in a specific order (DevInfo, Battery, HID, Custom).
HID service is required even though commands go through the custom Berbel service.
Just an ESP32 dev board. Uses NimBLE stack for ~100KB heap savings, leaving enough room for WiFi + MQTT on the shared radio.
Compatible hoods
Should work with all Berbel hoods with berbel Connect 2.0 (manufactured November 2020+):
Island, wall-mounted, headroom, and built-in hoods including Skyline Frame/
Edge/Curve/Sound/Light/Round, Ergoline, Glassline, Blockline, Smartline, Formline, Firstline.
Amazing! Thank you very much!
It works so far—is there also a way to dim the light and possibly adjust the light color from 2700 to 6500K? Or is something like that planned?
Thank you for amazing work. You mentioned the hardware requirements to run is, but not the software requirements. How do I get “pio” which is need for installing the software on the ESP32?
Great Project.
Was looking forward for something like this for quite some time.
Did not test it out yet but I have one question:
Will the original BT remote still work when the hood is paired to the ESP? (Can the hood be connected to both at the same time?)
Very nice work!
In the last month I have done nearly the same.
My target is to come up with an ESPhome setup.
I can fully confirm your analysis regarding advertising 128 bit service data, and the characteristics and UUIDs.
Also the 2-byte button pressed from 0x01 to 0x0D is the same.
I used the app “nRF Connect” on an iPhone and paired that with the BFB 6bT. On characteristics f001 I have sent all 18 combinations of one 1 and seventeen 0s. (If you send a 9, it means “blinking”). My result is similar to yours, with some additional infos:
- 0: 1
- 1:
- 2: 3
- 3: 2
- 4: Lampe oben
- 5: P
- 6: Pfeile im Kreis (missing)
- 7: Dreieck nach rechts (missing)
- 8: Lampe nach unten
- 9: Dach nach oben
- 10: Nachlauf Kuchensegment
- 11: Kreis mit Punkt (missing)
- 12:
- 13: Dach nach unten
- 14:
- 15:
- 16:
- 17:
One thing that works a little bit different on my side:
-The hood connects to my ESP32 although I do not spoof the MAC. ESPhome also has some more characteristics than the BFB 6bT. I can read out the 9-byte state from the hood already.
EDIT: Since your approach works perfectly I will discontinue my project.
The connection from the hood to my original BFB 6bT stays, even when the hood is additionally connected to my ESP32 running ESPhome. E.g. I press a light button in the hood, the LED on my BFB lights up and the corrsponding 9-bytes are received on the ESP32.
EDIT: I tried it out with this Remote Emulator. Works perfectly. Hood is connected to both the ESP32 and the BFB 6bT in parallel. All three device work in union.
I have an idea for improvement but sadly I am not really familiar with github so I will just post it here.
Make the hostname of the device variable.
In config.h define an hostname:
#define DEVICE_HOSTNAME "yourHostname"
In main.cpp refer to the hostname instead of the static berbel-remote name:
line 661: WiFi.setHostname(DEVICE_HOSTNAME);
line 672: ArduinoOTA.setHostname(DEVICE_HOSTNAME);
line 711: if (mqtt.connect(DEVICE_HOSTNAME, MQTT_USER, MQTT_PASS,
If thats a bad idea dont mind it, not really into coding
A bit offtopic:
Do you guys also use the autorun feature?
We have issues all the time that the hood doesnt lower when triggered via autorun (light and hood itself turns on).
Already contacted Berbel regarding this and they swapped the mainboard multiple times without success.
I would say this happens 1 in 10.
Maybe this Project will help me to make an autorun feature of my own which works better
This is very cool! I created an account just to say thanks Thorben.
I do have a WESCO EVRE-L Alto hood, but to all I found it must use the same as the Berbel remote. Will test this soon, but if someone has information or did this before, please let me know.
Hello @thfo - just disvovered this, looks great. I will give it a try this weekend.
I have been trying to get this to work for a while now. My approach is slightly different; I try to connect an ESP32 physically to the expansion port of my Berbel, emulating the Connect 2.0.
Berbel internally uses a variant of I2C communication; but with lots of protocol quirks, especially for addressing and signalling changes. I mostly got it to work but it is still far from "production readiness".
In case you are interested, I could share my findings with you. Let me know.
Anyways - thanks for your solution. If this works on my end, it might make my endevaours redundant
Hello Malte,
I'm interested in integrating my Skyline Edge from 2022 into my Home Assistant, too. For app integration it is to old, but the simulated BFB 6bT from @thfo is working fine.
Sadly I can't control the LEDs directly (brightness and color temperature).
I already tried to read the I2C (SMBUS) - I got some signals, but wasn't able to assign them.
I'd be happy to contribute to your project since Berbel isn't able to offer a working solution
I have the Berbel Ergoline 2 - also from 2022; though I believe it was build a year earlier.
Yesterday I tried Thorbens solution and it worked right away. Had to press and hold 1 + P to pair the emulated remote, it connected right away.
I also cannot set brightness and colour temperature directly. This might be a limitation by emulating the remote. I think it might be necessary to simulate a button "long press" to adjust the brightness, which will bring timing issues.
Using my approach - direct link / I2C - I am able to set the values for the lights directly to a desired value. So on the bus it can be done.
That being said, I'll see if I can publish my current code and findings from reverse engineering to Github over the next couple days, so you or others can contribute. My approach is to make this an ESPHome custom component which just runs on a ESP32. It will, however, need some additional hardware like logic-level-shifter, Mosfet to pull the signalling line low etc.
Nice. Wanted to do the same for my Skyline Edge Play (which uses the BFB 7bT). Even bought a nRF52840 dongle already and stumbled over you project just now. Will try it out based on your project.
does anyone else get a BLE disconnect after a day or so? I had it a few times now. Only thing that works is to press the berbel couple button and it works again (for a day or so). How can I solve this?
