Best Deadbolt with HA
I am looking for a deadbolt that is fully functional with HA. I currently run several zigbee devices using zigbee2MQTT. Searching the forum and reading tons of posts but can’t seem to find a lock that just works. I was looking into the Wyze lock, but I’m not sure it works with zigbee2mqtt as all I can find is info using ZHA. If anyone has recommendations for a lock that is either natively supported or doesn’t require a lot of work around programming, I would appreciate it.
The kwikset convert just works, pair it up and it’s good to go. It just doesn’t have a keypad though
Thanks, it works with Zigbee2MQTT also?
Yeah, just make sure you get the zigbee version not zwave
Awesome Thanks!!
If you prefer Schlage over Kwikset, and desire a numeric touchpad, consider:
Schlage Connect Smart Deadbolt Zigbee certified
