of course, there are a lot of thermostats available - the devices from AVM (Fritz! Smarthome) for example - which are working with DECT… or just many of the other smart thermostats that are available on the market.
In terms of the eco-system, I still beleive, Homematic is one of the devices that would fit most of your requirements…
The AVM devices are also working locally - and can act as an DECT Repeater also (usefull if you have a cordless phone…)
But I don’t know, if there are other devices like window Sensors available…
Most other devices are working cloud based, as far as I know…
Then, there is another device from EQ3 - a Bluetooth based thermostat - but personally, I don’t think that this would be an option I would go for - at least, I haven’t tested any of these devices, so I don’t know how secure they are (pairing, etc.)
I also found another thermostat, which seems to work with Tuya / Zigbee… so it should also be possible to implement them into HomeAssistant - at least, by adding a local zigbee usb-stick to the server it should be possible to keep them local.
But again, I don’t know how this does work with other devices like window sensors, etc.
Here, WallyR has mentioned a valid Point.
If you are just going for a thermostat to controll temperature through home assistant, most of the devices should be OK.
But if you want to have some kind of logic behind your heating profiles, more work is required.
You need to create the automations in HomeAssistant or Node Red in order to close the vent when a WIndow is open.
This would require HomeAssistant to be available all the time - and your Automation should not stuck or break… etc.
HomeMatic in this case can even do this basic Job even if your HomeAssistant AND your CCU aren’t available right now…
